Discuss
DW fill
 in
Dishwasher Repair
How do I tell if sufficient water is entering the DW? Is the water supposed to cover the heater element?
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » DW fill
  #1 (permalink)
Old 09-12-2013, 01:22 PM
Junior Member
ionized is on a distinguished road
Default DW fill
Model Number: 66515798790   Brand: Kenmore   Age: More than 10 years
How do I tell if sufficient water is entering the DW? Is the water supposed to cover the heater element? Should it go up to the bottom of the float, maybe?
Related Models
Kenmore 66515798790 UNDERCOUNTER DISHWASHER
Kenmore 66515798791 UNDERCOUNTER DISHWASHER
Kenmore 66515798792 UNDERCOUNTER DISHWASHER
Kenmore 66515798793 UNDERCOUNTER DISHWASHER
Kenmore 66515801890 DISHWASHER
Kenmore 66515801891 DISHWASHER
Kenmore 66515805890 DISHWASHER
Kenmore 66515805891 DISHWASHER
Kenmore 6651580590 DISHWASHER
Kenmore 6651580591 DISHWASHER
Kenmore 6651580592 DISHWASHER
Kenmore 66515808890 DISHWASHER
Kenmore 66515808891 DISHWASHER
Kenmore 66515812990 DISHWASHER
Kenmore 66515812992 DISHWASHER
Kenmore 6651581590 DISHWASHER
Kenmore 6651581591 DISHWASHERS
Kenmore 6651581592 DISHWASHER
Kenmore 6651581593 DISHWASHER
Kenmore 66515817990 DISHWASHER
Kenmore 66515817992 DISHWASHER
Kenmore 66515819990 DISHWASHER
Kenmore 66515819992 DISHWASHER
Kenmore 66515821690 DISHWASHER
Kenmore 66515821691 UNDERCOUNTER DISHWASHER
Kenmore 66515821692 UNDERCOUNTER DISHWASHER
Kenmore 66515822000 DISHWASHER
Kenmore 66515824000 DISHWASHER
Kenmore 66515825690 DISHWASHER
Kenmore 66515825691 UNDERCOUNTER DISHWASHER
Kenmore 66515825692 UNDERCOUNTER DISHWASHER
Kenmore 66515828690 UNDERCOUNTER DISHWASHER
Kenmore 66515828691 UNDERCOUNTER DISHWASHER
Kenmore 66515828692 UNDERCOUNTER DISHWASHER
Kenmore 66515829000 DISHWASHER
Kenmore 66515831790 DISHWASHER
Kenmore 66515831791 DISHWASHER
Kenmore 66515831792 DISHWASHER
Kenmore 66515831793 DISHWASHER
Kenmore 66515831794 DISHWASHER
Kenmore 66515832000 DISHWASHER
Kenmore 66515834000 DISHWASHER
Kenmore 66515835790 DISHWASHER
Kenmore 66515835791 DISHWASHER
Kenmore 66515835792 DISHWASHER
Kenmore 66515835793 DISHWASHER
Kenmore 66515835794 DISHWASHER
Kenmore 66515838790 DISHWASHER
Kenmore 66515838791 DISHWASHER
Kenmore 66515838792 DISHWASHER
Kenmore 66515838793 DISHWASHER
Kenmore 66515838794 DISHWASHER
Kenmore 66515839000 DISHWASHER
Kenmore 6651584990 DISHWASHER
Kenmore 6651584991 DISHWASHER
Kenmore 6651584992 DISHWASHER
Kenmore 6651584993 UNDER COUNTER DISHWASHER
Kenmore 66515862990 DISHWASHER
Kenmore 66515862992 DISHWASHER
Kenmore 6651586580 DISHWASHER
Kenmore 6651586581 DISHWASHER
Kenmore 66515867990 DISHWASHER
Kenmore 66515867992 DISHWASHER
Kenmore 66515869990 DISHWASHER
Kenmore 66515869992 DISHWASHER
Kenmore 66515872000 DISHWASHER
Kenmore 66515874000 DISHWASHER
Kenmore 6651587580 DISHWASHER
Kenmore 66515879000 DISHWASHER
Kenmore 6651587980 DISHWASHER
Kenmore 6651587981 DISHWASHER
Kenmore 6651587982 DISHWASHER
Kenmore 6651587983 DISHWASHER
Kenmore 66515882000 DISHWASHER
Kenmore 66515884000 DISHWASHER
Kenmore 6651588580 Dishwasher
Kenmore 6651588581 Dishwasher
Kenmore 6651588582 Dishwasher
Kenmore 6651588583 DISHWASHER
Kenmore 6651588584 DISHWASHER
Kenmore 66515887000 DISHWASHER
Kenmore 66515889000 DISHWASHER
Kenmore 66515891790 DISHWASHER
Kenmore 66515891791 DISHWASHER
Kenmore 66515891792 DISHWASHER
Kenmore 66515891793 DISHWASHER
Kenmore 66515891794 DISHWASHER
Kenmore 66515892100 UNDERCOUNTER DISHWASHER
Kenmore 66515894100 UNDERCOUNTER DISHWASHER
Kenmore 66515895790 DISHWASHER
Kenmore 66515895791 DISHWASHER
Kenmore 66515895792 DISHWASHER
Kenmore 66515895793 DISHWASHER
Kenmore 66515895794 DISHWASHER
Kenmore 66515898790 DISHWASHER
Kenmore 66515898791 DISHWASHER
Kenmore 66515898792 DISHWASHER
Kenmore 66515899100 UNDERCOUNTER DISHWASHER
Kenmore 6651590840 KENMORE DISHWASHER
Kenmore 66515912000 DISHWASHER
Kenmore 66515912001 DISHWASHER
Kenmore 66515914000 DISHWASHER
Kenmore 66515914001 DISHWASHER
Kenmore 6651591680 DISHWASHER
Kenmore 6651591681 DISHWASHER
Kenmore 66515919000 DISHWASHER
Kenmore 66515919001 DISHWASHER
Kenmore 66515921690 UNDERCOUNTER DISHWASHER
Kenmore 66515921691 UNDERCOUNTER DISHWASHER
Kenmore 66515921692 UNDERCOUNTER DISHWASHER
Kenmore 66515922000 DISHWASHER
Kenmore 66515922001 DISHWASHER
Kenmore 66515923000 DISHWASHER
Kenmore 66515923001 DISHWASHER
Kenmore 66515924000 DISHWASHER
Kenmore 66515924001 DISHWASHER
Kenmore 66515925690 UNDERCOUNTER DISHWASHER
Kenmore 66515925691 UNDERCOUNTER DISHWASHER
Kenmore 66515925692 UNDERCOUNTER DISHWASHER
Kenmore 66515928690 UNDERCOUNTER DISHWASHER
  #2 (permalink)
Old 09-12-2013, 04:16 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
take your supply line put it in a 1 gallon empty container you should be able to fill the gallon jug in 1 minute if you don't you have too low of water pressure. It depends on your float switch it should lift the float switch up and the switch should turn the water off from coming in.
  #3 (permalink)
Old 09-12-2013, 05:26 PM
Junior Member
Default
Thanks, would it be better to check the rate after the supply valve or even the volume? That way I'd know if the supply valve was clogged.
  #4 (permalink)
Old 09-13-2013, 06:31 PM
Senior Member
Default
Remove the connection at your water inlet valve on you dishwasher and take that hose to a gallon.......so that way it eliminates the dishwasher so you can isolate your problem and go from there
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fill solenoid stutters during fill cycle kspark Washer Repair 3 04-03-2013 06:13 AM
Washer will not fill after replacing fill valve toddf Washer Repair 1 12-03-2010 12:39 PM
no fill for wash but will fill for rinse CSM Dishwasher Repair 3 05-12-2009 12:13 PM
wont fill is it the fill valve acman727 Dishwasher Repair 1 03-14-2009 04:40 PM
Icemaker fill guide and fill tube freezing Cyberheater Refrigerator & Freezer Repair 6 02-05-2009 04:49 PM
