Discuss
no water
 in
Dishwasher Repair
Dish washer working fine. Next load ran thru cycle ok, when opened dry soap at bottom and dishes still dirty.
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » no water
  #1 (permalink)
Old 10-10-2009, 02:54 PM
Junior Member
phebert is on a distinguished road
Default no water
Model Number: SUD5000KQ0   Brand: Whirlpool   Age: 1 - 5 years
Dish washer working fine. Next load ran thru cycle ok, when opened dry soap at bottom and dishes still dirty. Checked other cycles rise, heavy duty, ect. same issue -- no water. Checked supply line & hose all ok. Any info on common concerns? Diagram on how it works? Electrical problem? How about a valve or screen?
I tried search feature nothing on this model but found no info.
Thanks in advance for any info.
Ads By Google
Related Models
Whirlpool SUD5000KQ0
Whirlpool SUD5100MQ0 Undercounter Dishwasher
Whirlpool SUD6000HQ0
Whirlpool SUD6000HQ1
Whirlpool SUD7000MS0 Undercounter Dishwasher
Whirlpool SVC80W
Whirlpool SVC80W1
Whirlpool SVC80W2
Whirlpool SVC80W3
Jenn-Air SVD48600B Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600BC Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600P Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PC Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PF Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PG Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PK Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PR Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PT Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PU Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600W Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600WC Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310S Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310S-C Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SD Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SF Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SG Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SK Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SR Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SU Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVE47100B Range - S/c S/i Ddraft Ele
Jenn-Air SVE47100BC Range - S/c S/i Ddraft Ele
Jenn-Air SVE47100W Range - S/c S/i Ddraft Ele
Jenn-Air SVE47100WC Range - S/c S/i Ddraft Ele
Jenn-Air SVE47500B Range - S/c S/i Ddraft Ele
Jenn-Air SVE47500W Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600B Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600BC Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600W Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600WC Range - S/c S/i Ddraft Ele
Jenn-Air SVE87600B Range - S/c S/i Ddraft Ele
Jenn-Air SVE87600W Range - S/c S/i Ddraft Ele
Whirlpool SVF100W0
Whirlpool SVF100W1
Whirlpool SVF12FRHW00
Whirlpool SVF15NRHW00
Whirlpool SVF15NRHW01
Whirlpool SVF15NRHW02
Whirlpool SVF15NRJW00
Whirlpool SVF20NRKQ00
Whirlpool SVF60W0
Whirlpool SVF60W1
Whirlpool SVF70W0
Whirlpool SVF70W1
Whirlpool SVF75W0
Whirlpool SVF75W1
Whirlpool SVF75W2
Whirlpool SVF80W0
Whirlpool SVF80W1
Whirlpool SVF90W0
Whirlpool SVF90W1
Whirlpool SVP100W0
Whirlpool SVP50W0
Whirlpool SVP60W0
Whirlpool SVP60W1
Whirlpool SVP70W0
Whirlpool SVP75W0
Whirlpool SVP80W0
Whirlpool SVP90W0
Whirlpool SVU100W0
Whirlpool SVU100W1
Whirlpool SVU100W2
Whirlpool SVU60W0
Whirlpool SVU60W1
Whirlpool SVU60W2
Whirlpool SVU70W0
Whirlpool SVU70W1
Whirlpool SVU70W2
Whirlpool SVU80W0
Whirlpool SVU80W1
Whirlpool SVU80W2
Whirlpool SVU90W0
Whirlpool SVU90W1
Whirlpool SVU90W2
Amana SW22H Ref - SXS/I&W
Amana SW22MBG Ref - SXS/I&W
Amana SW22MBL Ref - SXS/I&W
Amana SW22MBW Ref - SXS/I&W
Amana SW25H Ref - SXS/I&W
Amana SWDT22H Ref - SXS/I&W
Amana SWDT25H Ref - SXS/I&W
Whirlpool SWF100W0
Whirlpool SWF100W2
Whirlpool SWF60W0
Whirlpool SWF60W2
Whirlpool SWF70W0
Whirlpool SWF70W2
Whirlpool SWF80W0
Whirlpool SWF80W2
Whirlpool SWF80W8
Whirlpool SWF80W9
Whirlpool SWF90W0
Whirlpool SWF90W1
Whirlpool SWF90W2
Amana SWP25H Ref - SXS/I&W
Whirlpool SWP70W0
Whirlpool SWP80W0
Whirlpool SWP90W0
Amana SWPD25H Ref - SXS/I&W
White Westinghouse SWS1233CQ0 White Westinghouse/washer
White Westinghouse SWS1233CQ1 White Westinghouse/washer
White Westinghouse SWS1233CS0 White Westinghouse/washer
White Westinghouse SWS1233CS1 White Westinghouse/washer
White Westinghouse SWS1339CC1 White Westinghouse/washer
White Westinghouse SWS1339CC2 White Westinghouse/washer
White Westinghouse SWS1549AQ0 Washer - W.westinghouse
  #2 (permalink)
Old 10-11-2009, 04:07 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL SUD5000KQ0 | AppliancePartsPros.com
Could be one of the following:
Overflow/float. Check that the float is not stuck in the up position. Switch should be closed, check it with a meter.
Valve filter screen. Remove the valve and check it. If it is clogged up clean it. Do not remove it as it is there to keep crud out of the valve, which could hold it open and cause a flood. Also a good idea to drain some water out of your hot water tank as crud collects in the bottom of the tank.
Valve itself. Check that it is getting voltage when it should (120 volts). If yes and the filter screen is clean the valve is shot.
Controller. If the valve is not getting voltage and the overflow/float switch is closed, could be the contacts in the timer are shot.
Bad wire. Check the wires from the valve to the control for continuity.
Cannot find tech info on this unit but perhaps the following will help.
http://www.applianceaid.com/dishwash.html
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
water lines to hook up to the water valve on a kenmore coldspot simonf22 Refrigerator & Freezer Repair 0 12-17-2009 12:16 PM
How Can I replace Water Pipe that is connected from Water Dispenser valve to Dispense Rashmikant Refrigerator & Freezer Repair 0 11-23-2009 03:04 PM
Motor humming and water comes but blades don't spin (water pressure problem?) mtheriault3 Dishwasher Repair 4 01-11-2009 04:18 PM
made clunking sound on ice and water dispenser now iced nor water works crazyman Refrigerator & Freezer Repair 1 09-08-2008 01:12 PM
Whirlpool LA5300XM Cold water trickles, warm water flows properly ajaysheetal Washer Repair 2 02-14-2008 04:49 PM
