Discuss
Door Leak on LG Dishwasher LDF6920ST
 in
Dishwasher Repair
I have a LG dishwasher, model LDF6920ST. Currently experiencing water leakage along bottom of door. I have ordered a new
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Door Leak on LG Dishwasher LDF6920ST
  #1 (permalink)
Old 09-08-2013, 09:10 AM
Junior Member
snapline is on a distinguished road
Default Door Leak on LG Dishwasher LDF6920ST
Model Number: LDF6920ST   Brand: -other-   Age: 1 - 5 years
Currently experiencing water leakage along bottom of door. I have ordered a new door gasket for the unit, but I fear there is also a problem with the 'lower door seal'.
Not sure about that, so I have ordered the door gasket and will install when received and check leak situation.
Having said that IF the unit requires a lower door seal, I have found that LG now requires one to purchase a full interior door liner. Seems the lower seal is crimped into place on the replacement part. I began pulling the interior door liner here and found that the liner is 'spring loaded'. I stopped due to fears of not being able to reassemble properly.
Are there any instructions for replacement of same?
Would appreciate any and all info.
Thanks!
Snapline
Related Models
 LDF6920ST Dishwasher
 LDF6920WW Dishwasher
 LDF7810BB Dishwasher
 LDF7810ST Dishwasher
 LDF7810WW Dishwasher
 LDF7811BB Dishwasher
 LDF7811ST Dishwasher
 LDF7811WW Dishwasher
 LDF7932ST Dishwasher
 LDF8812ST Dishwasher
 LDF9810ST Dishwasher
 LDF9932ST Dishwasher
Admiral LDG1000AAE DRYER- GAS
Maytag LDG110 DRYER- GAS
Maytag LDG18CA MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG18CM MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG18CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG18CT MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG19CD MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG19CS MANUAL, PARTS (DRYER GAS)
Maytag LDG19CT MANUAL, PARTS (DRYER GAS)
Maytag LDG210 DRYER- GAS
Maytag LDG212 DRYER- GAS
Maytag LDG21CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG22CS MANUAL, PARTS (DRYER GAS)
Maytag LDG22CT MANUAL, PARTS (DRYER GAS)
Maytag LDG23CD MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG24CA MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG24CM MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG24CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG24CT MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG25CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG26CA MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag LDG26CD MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag LDG26CS MANUAL, PARTS (DRYER GAS)
Maytag LDG26CT MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag LDG27CA MANUAL, PARTS (DRYER GAS)
Maytag LDG27CD MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag LDG27CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG27CT MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG303 DRYER- GAS
Maytag LDG30CMD MANUAL, PARTS (DRYER GAS)
Maytag LDG312 DRYER- GAS
Maytag LDG313 DRYER- GAS
Maytag LDG31CA MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG31CM MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG31CT MAYTAG LAUNDRY (DRYER GAS)
Frigidaire LDG333PEW0 Frg(v0) / Gas Dryer
Maytag LDG33CA MANUAL, PARTS (DRYER GAS)
Maytag LDG33CM MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG34CD MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG34CQ MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG382 DRYER- GAS
Maytag LDG4000 DRYER- GAS
Maytag LDG4000AAL DRYER- GAS
Maytag LDG4000AAW DRYER- GAS
Maytag LDG4000ABL DRYER- GAS
Maytag LDG4000ABW DRYER- GAS
Maytag LDG410 DRYER- GAS
Maytag LDG412 DRYER- GAS
Maytag LDG482 DRYER- GAS
Maytag LDG490 DRYER- GAS
Maytag LDG4910 DRYER- GAS
Maytag LDG4910AAL DRYER- GAS
Maytag LDG4910AAW DRYER- GAS
Maytag LDG4914AAE DRYER- GAS
Maytag LDG4914AAL DRYER- GAS
Maytag LDG4914AAM DRYER- GAS
Maytag LDG4916AAE DRYER- GAS
Maytag LDG4916AAM DRYER- GAS
Maytag LDG5004AAW DRYER- GAS
Maytag LDG5004ABW DRYER- GAS
Maytag LDG5005AAE DRYER- GAS
Maytag LDG5005ABE DRYER- GAS
Maytag LDG510 DRYER- GAS
Maytag LDG512 DRYER- GAS
Maytag LDG590 DRYER- GAS
Maytag LDG5910 DRYER- GAS
Maytag LDG5910AAL DRYER- GAS
Maytag LDG5910AAW DRYER- GAS
Maytag LDG5914AAE DRYER- GAS
Maytag LDG5914AAL DRYER- GAS
Maytag LDG5914AAM DRYER- GAS
Maytag LDG5916AAE DRYER- GAS
Maytag LDG5916AAM DRYER- GAS
Maytag LDG6004AAW DRYER- GAS
Maytag LDG610 DRYER- GAS
Maytag LDG612 DRYER- GAS
Maytag LDG6914AAE DRYER- GAS
Maytag LDG6914AAL DRYER- GAS
Maytag LDG6914AAM DRYER- GAS
Maytag LDG710 DRYER- GAS
Maytag LDG712 DRYER- GAS
Maytag LDG713 DRYER- GAS
Maytag LDG7304AAE DRYER- GAS
Maytag LDG7304AAL DRYER- GAS
Maytag LDG7304AAM DRYER- GAS
Maytag LDG7304ABE DRYER- GAS
Maytag LDG7304ABL DRYER- GAS
Maytag LDG7304ABM DRYER- GAS
Maytag LDG7304AGE DRYER- GAS
Maytag LDG7304AGL DRYER- GAS
Maytag LDG7304AGM DRYER- GAS
Maytag LDG7304EGE DRYER- GAS
Maytag LDG7304EGL DRYER- GAS
Maytag LDG7304EGM DRYER- GAS
Maytag LDG7314AAE DRYER- GAS
Maytag LDG7314AAL DRYER- GAS
Maytag LDG7314AAM DRYER- GAS
Maytag LDG7334AAE DRYER- GAS
Maytag LDG7334AAL DRYER- GAS
Maytag LDG7334AAM DRYER- GAS
Maytag LDG7400 DRYER- GAS
Maytag LDG7400AAL DRYER- GAS
Maytag LDG7400AAW DRYER- GAS
Maytag LDG7400ABL DRYER- GAS
Maytag LDG7400ABW DRYER- GAS
Maytag LDG7480AAL DRYER- GAS
Maytag LDG7480AAW DRYER- GAS
Maytag LDG7480ABL DRYER- GAS
  #2 (permalink)
Old 09-08-2013, 06:54 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
First off remove bottom panel to make sure your supply hose isn't leaking. Your unit must be perfectly level from side to side and front to back otherwise alot of models will leak the front. Also inspect the spray arms for cracks and make sure to turn the unit on and to open the door quick so you can see the spray arms rotating during cycling if not this will cause a leak as well. It's rarely the tub gasket that most people think and the two on the sides are just vapor barriers and don't stop leaks persay. Watch some video's to help you find your problem
dishwasher leaks from door - YouTube
  #3 (permalink)
Old 09-09-2013, 08:39 AM
Junior Member
Default
Thank you for this information. I will research all and move forward with a repair hopefully.
Very much appreciate your time and your knowledge.
Thanks again!
  #4 (permalink)
Old 09-14-2013, 10:56 AM
Junior Member
Default Leak Continues
Well, to update I have replaced BOTH door gaskets on this dishwasher. They were in need of replacement so no loss there.
Having siad that the leak continues!
I am at a point, AFTER checking level, lower spray arm, upper spray arm, which all are good to go forward and replace the door gasket, which is along the bottom of the door itself.
I have 'felt' along the bottom edge of the door and can feel this gasket as it lays from left to right along the edge of the door along the bottom. It seems to be have a 'bubble' or rounded surface to it. It would be logical that this shape continue along its' entire length from the left lower corner of the door assembly going horizontally across to the lower right corner of the door assembly. IT DOES NOT!
At three [3] spots across its' horizontal length, the shape goes 'flat'! This makes no sense to me since when the door closes this gaskets presses down on a smooth surface with no change in its' surface. There are no humps or bumps that would cause such a modification in the shaping of the gasket.
Interestingly enough, the leak in the door gasket relates directly to one of these flat areas! Also it should be noted, that there is a white plastic vent, [on the bottom of the door assembly towards the lower left corner]. My assumption is this is for intake or exhausting of air, etc. Not sure, but the leak is in this area.
I have researched and found that in order to replace this gasket I have to purchase part AP4439526 at the price of $159.99 + shipping and tax.
I would do so immediately IF I knew this would solve the issue.
Can anyone assist me with an answer as to why this gasket has a different shape as described and confirm, that my conclusions are correct please. I cannot afford to waste money on parts that are needed!
Thanks again!
Snapline
  #5 (permalink)
Old 01-12-2014, 08:33 PM
Junior Member
ehart3000 is on a distinguished road
Default Here's a potential fix
I had this problem and turns out it didn't have anything to do with the door gasket. It was a problem with the casing assembly for the vented drying system. Here's a detailed fix that requires a new part, phillips screwdriver and about 20-30 minutes of your time. Help! My LG Dishwasher LDF6920ST Is Leaking Water | A Lesson Learned.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE dishwasher door leak colinburt Dishwasher Repair 1 02-24-2013 02:13 PM
Dishwasher Door Leak MUDMOMM Dishwasher Repair 0 04-04-2011 12:29 PM
Dishwasher Front Door Leak Archfsc Dishwasher Repair 3 02-23-2010 08:04 AM
Dishwasher door leak maloo Oven Repair (including Ranges and Cooktops) 2 06-12-2009 06:36 PM
dishwasher door leak greeniguaina Dishwasher Repair 0 01-22-2008 04:26 PM
