Discuss
Bosch Dishwasher APExx Fails to fill. "Check Water supply"
 in
Dishwasher Repair
I have attempted to troubleshoot the "Check Water Supply" LED Error message on my Bosch SHX99A15UC/19. I looked at the
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch Dishwasher APExx Fails to fill. "Check Water supply"
  #1 (permalink)
Old 09-04-2013, 11:49 AM
Junior Member
fixmyboschdw is on a distinguished road
Question Bosch Dishwasher APExx Fails to fill. "Check Water supply"
Model Number: SHX99A15UC/19   Brand: Bosch   Age: 5 - 10 years
I looked at the posts here as well as on the web and youtube to gather some intel on what might be the issue.
I was hoping to find the relevant Manual on this site but the one posted is not correct for my model #.
Does anyone have the repair manual with wiring diagram for Bosch SHX99A15UC/19?
Here's what I know:
There is water to the Dishwasher. Checked the supply line that is tapped off the sink.
When turned on and set for Auto-wash or rinse and hold the Dishwasher Drain pump and impeller is engaged and any water if I manually add is pumped out. After this the machine does not fill and then times out after say 5-10 minutes with the Check Water Supply message on the display panel.
I have cleared the drain tub and removed the back-flow stopper under the Impeller cover. I have re-assembled and still no resolution.
I assumed (incorrectly) that the most likely culprit was the Inlet Valve solenoid and ordered it from Sears along with a New Basket filter which had begun to deteriorate and I believe some food debris probably made it past the filter over time..
I have measured resistance across the valve leads and basically measures 1K ohms...
I originally thought it was reading 1ohm but after rechecking I realized my older digital meter reads out by default in K Ohms... so it looks like I replaced the Valve for no reason as both measure 1K ohm...
When I place a meter on the 2 Terminals on the Valve I see no voltage across but when measured against ground I measure 115vac on both legs while the dishwasher is attempting to run the cycle.
Does anyone have the right Service Manual or Troubleshooting tips for this Model Dishwasher????
I don't know what other switches may be inline with the Water Inlet valve but I am starting to think that it has to be another safety switch that is engaged.
Any other suggestions that I might try...
Help..!
Thanks,
Pat
Related Models
Bosch SHX99B05 UC/14 (FD 8212-)
Bosch SHX99B06 UC/14 (FD 8212-)
Bosch SHY56A02 UC/14 (FD8301-)
Bosch SHY56A05 UC/14 (FD8301-)
Bosch SHY56A06 UC/14 (FD8301-)
Bosch SHY66C02 UC/14 (FD8301-)
Bosch SHY66C05 UC/14 (FD8301-)
Bosch SHY66C06 UC/14 (FD8301-)
Bosch SHY99A02 UC/14 (FD 8212-)
Bosch SHY99A05 UC/14 (FD 8212-)
Bosch SHY99A06 UC/14 (FD 8212-)
Amana SI19E REF - SXS/I&W
General Electric SIG140060B SIGNATURE REFRIGERATOR
General Electric SIG1480A66WH DISHWASHER
General Electric SIG1482A68BA DISHWASHER
General Electric SIG60100T0WG SIGNATURE WASHER
General Electric SIG7010ET0WG SIGNATURE ELECTRIC DRYER
General Electric SIG7010ET1WG Electric dryer
Admiral SILVER22 REF - SXS/I&W
Admiral SILVER24 REF - SXS/I&W
Maytag SK525-2W REF - SXS
Maytag SK535-2 REF - SXS/I&W
Gaggenau SK590-2 REF - BOTTOM MOUNTS
Hardwick SKG4622MGA639R RANGE-F/S CONT CLEAN GAS
Hardwick SKG4622MGW639R RANGE-F/S CONT CLEAN GAS
Hardwick SKG9611A540R RANGE-F/S CONT CLEAN GAS
Hardwick SKG9611W540R RANGE-F/S CONT CLEAN GAS
Amana SKI22F REF - SXS/I&W
Amana SKI22F-A REF - SXS/I&W
Amana SKI22F-C REF - SXS/I&W
Amana SKI22F-G REF - SXS/I&W
Amana SKI22FL REF - SXS/I&W
Hardwick SKJ7141819DE WALLOVEN- CONT CLEAN GAS
Maytag SL10AN-A01 STACKED LAUNDRY- ELE
Maytag SL10AN-A02 STACKED LAUNDRY- ELE
Maytag SL10AN-A03 STACKED LAUNDRY- ELE
Maytag SL11AA STACKED LAUNDRY- ELE
Maytag SL11AN STACKED LAUNDRY- ELE
General Electric SL208 Room air conditioner
General Electric SL210 Room air conditioner
General Electric SL212 Room air conditioner
General Electric SL214 Room air conditioner
General Electric SL217 Room air conditioner
General Electric SL220 Room air conditioner
General Electric SL223 Room air conditioner
Amana SL22F REF - SXS/I&W
Amana SL22F-A REF - SXS/I&W
Amana SL22F-C REF - SXS/I&W
Amana SL22F-G REF - SXS/I&W
Amana SL22F-L REF - SXS/I&W
Amana SL22G REF - SXS/I&W
Amana SL22GL REF - SXS/I&W
Amana SL22JB REF - SXS/I&W
Amana SL22JB Ref - SXS/I&W
Amana SL22MBG REF - SXS/I&W
Amana SL22MBL REF - SXS/I&W
Amana SL22MBW REF - SXS/I&W
Amana SL25G REF - SXS/I&W
Amana SL25GL REF - SXS/I&W
Amana SL25H REF - SXS/I&W
Amana SL25J REF - SXS/I&W
Amana SL25J Ref - SXS/I&W
Amana SL25M2L REF - SXS/I&W
Amana SL25M2W REF - SXS/I&W
Amana SL25MG REF - SXS/I&W
Amana SL25ML REF - SXS/I&W
Amana SL25MW REF - SXS/I&W
Amana SLD22JB REF - SXS/I&W
Amana SLD22MB2L REF - SXS/I&W
Amana SLD22MB2W REF - SXS/I&W
Amana SLD22MBG REF - SXS/I&W
Amana SLD22MBL REF - SXS/I&W
Amana SLD22MBW REF - SXS/I&W
Amana SLD25J REF - SXS/I&W
Amana SLD25JB REF - SXS/I&W
Amana SLD25JP REF - SXS/I&W
Amana SLD25M2G REF - SXS/I&W
Amana SLD25M2L REF - SXS/I&W
Amana SLD25M2W REF - SXS/I&W
Amana SLD25MB2L REF - SXS/I&W
Amana SLD25MB2W REF - SXS/I&W
Amana SLD25MBG REF - SXS/I&W
Amana SLD25MBL REF - SXS/I&W
Amana SLD25MBW REF - SXS/I&W
Amana SLD25MG REF - SXS/I&W
Last edited by fixmyboschdw : 09-04-2013 at 05:43 PM. Reason: I incorrectly listed bad information on the diagnosis...
  #2 (permalink)
Old 09-04-2013, 06:13 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Free Manual Downloads PDF Owner Guides and Technical Specification Manuals | ManualOwl.com For your schematics..............
Disconnect your water supply line and put it in a 1 gallon empty jug..........Turn the valve back on and you should be able to fill the jug within 1 minute if you can't you have a water supply issue. If you have 120v at the solenoid and no water coming in pull it off and check the inlet filter screen on the back for debris and go from there.
  #3 (permalink)
Old 09-04-2013, 07:07 PM
Junior Member
Default
Thank you for replying.
The intake water solenoid valve is new as I replaced it this afternoon so the inlet screen was clean as would be expected from a new part.
I will check the flow GPM as you mentioned and repost results.
Thanks, I will check the link for the manual!
Pat
  #4 (permalink)
Old 09-05-2013, 07:53 AM
Junior Member
Default
Water Flow tested from source this morning and water supply has plenty of flow. What might be the next step?
I checked the website ManualOwl for the manual of my DW but it did not have my model listed. So I think I am out of luck there...
The closest model that looks similar only had use and care manuals but nothing else.. so that won't help either.. Any suggestions as to where I might locate the wiring schematic that would be great!
  #5 (permalink)
Old 09-05-2013, 05:09 PM
Senior Member
Default
Try bosch customer service directly.
Bosch Home Appliances | Customer Service, Support, Repair & Parts
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch dryer stops, beeps, "Drying" and "End" lights on endyem Dryer Repair 3 12-31-2016 03:08 PM
Bosch axxis washer "water tap closed" error jstew0903 Washer Repair 1 07-28-2015 01:15 PM
Maytag Neptune MAH7500 "NF" cold water no fill on rinse vespula Washer Repair 10 10-28-2012 10:10 PM
Bosch SHU5306UC Dishwasher stuck at "1" minute Orangegreen Dishwasher Repair 0 08-18-2012 04:39 AM
Maytag washer "buzzes" but does not fill with water pkonrath147 Washer Repair 0 06-06-2008 12:21 AM
