Discuss
Water from duct assembly??
 in
Dishwasher Repair
What would cause water to flow through the duct assembly on my dishwasher? Have had unit for over two yrs
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Water from duct assembly??
  #1 (permalink)
Old 09-02-2013, 06:47 PM
Junior Member
Coachmac91 is on a distinguished road
Default Water from duct assembly??
Model Number: Lgbd2431lf0a   Brand: Frigidaire   Age: 1 - 5 years
Have had unit for over two yrs with no problem thought it was bottom door seal but it is airtight. There is water all over the floor coming out in a small stream right where the duct assembly is.
Related Models
Frigidaire LGBD2431LF0A DISHWASHER
Frigidaire LGBD2431LQ0A DISHWASHER
Frigidaire LGBD2431LW0A DISHWASHER
Frigidaire LGBD2432LB0A DISHWASHER
Frigidaire LGBD2432LF0A DISHWASHER
Frigidaire LGBD2432LQ0A DISHWASHER
Frigidaire LGBD2432LW0A DISHWASHER
Admiral LGC1330ADB SURFACE UNIT- GAS
Admiral LGC1330ADC SURFACE UNIT- GAS
Admiral LGC1330ADW SURFACE UNIT- GAS
Amana LGC20AW DRYER- GAS
Whirlpool LGC5000PQ0 29" GAS DRYER
Whirlpool LGC5000PQ1 29" GAS DRYER
Amana LGC50AW DRYER- GAS
Whirlpool LGC6646AN0 GAS DRYER
Whirlpool LGC6646AN1 GAS DRYER
Whirlpool LGC6646AN2 GAS DRYER
Whirlpool LGC6646AQ0 Residential Dryer
Whirlpool LGC6646AQ1 GAS DRYER
Whirlpool LGC6646AQ2 GAS DRYER
Whirlpool LGC6646AW0 Residential Dryer
Whirlpool LGC6646AW1 GAS DRYER
Whirlpool LGC6646AW2 GAS DRYER
Whirlpool LGC6646AZ0 Dryer
Whirlpool LGC6646AZ1 GAS DRYER
Whirlpool LGC6646AZ2 GAS DRYER
Whirlpool LGC6848AN0 GAS DRYER
Whirlpool LGC6848AN1 GAS DRYER
Whirlpool LGC6848AN2 GAS DRYER
Whirlpool LGC6848AN3 GAS DRYER
Whirlpool LGC6848AQ0 Residential Dryer
Whirlpool LGC6848AQ1 GAS DRYER
Whirlpool LGC6848AQ2 GAS DRYER
Whirlpool LGC6848AQ3 GAS DRYER
Whirlpool LGC6848AW0 GAS DRYER
Whirlpool LGC6848AW1 TECH SHEET - DRYER - REVISION REL.
Whirlpool LGC6848AW2 GAS DRYER
Whirlpool LGC6848AW3 GAS DRYER
Whirlpool LGC6848AZ1 GAS DRYER
Whirlpool LGC6848AZ2 GAS DRYER
Whirlpool LGC6848AZ3 GAS DRYER
Whirlpool LGC7646DQ0 GAS DRYER
Whirlpool LGC7646DQ1 GAS DRYER
Whirlpool LGC7646DZ0 GAS DRYER
Whirlpool LGC7646DZ1 GAS DRYER
Whirlpool LGC7848DQ0 GAS DRYER
Whirlpool LGC7848DQ1 GAS DRYER
Whirlpool LGC7848DZ0 GAS DRYER
Whirlpool LGC7848DZ1 GAS DRYER
Whirlpool LGC7858AN0 GAS DRYER
Whirlpool LGC7858AN1 GAS DRYER
Whirlpool LGC7858AN2 GAS DRYER
Whirlpool LGC7858AQ0 GAS DRYER
Whirlpool LGC7858AQ1 GAS DRYER
Whirlpool LGC7858AQ2 GAS DRYER
Whirlpool LGC7858AW0 Residential Dryer
Whirlpool LGC7858AW1 GAS DRYER
Whirlpool LGC7858AW2 GAS DRYER
Whirlpool LGC7858AZ0 GAS DRYER
Whirlpool LGC7858AZ1 GAS DRYER
Whirlpool LGC7858AZ2 GAS DRYER
Whirlpool LGC8858DQ0 GAS DRYER
Whirlpool LGC8858DQ1 GAS DRYER
Whirlpool LGC8858DZ0 GAS DRYER
Whirlpool LGC8858DZ1 GAS DRYER
Whirlpool LGC8858EQ0 GAS DRYER
Whirlpool LGC8858EQ1 DRYERS
Whirlpool LGC8858EQ2 GAS DRYER
Whirlpool LGC8858EQ3 GAS DRYER
Whirlpool LGC8858EZ0 GAS DRYER
Whirlpool LGC8858EZ1 DRYERS
Whirlpool LGC8858EZ2 GAS DRYER
Whirlpool LGC8858EZ3 GAS DRYER
Whirlpool LGC9000PW0 29" GAS DRYER
Whirlpool LGC9000PW1 29" GAS DRYER
Amana LGD20AW DRYER- GAS
Amana LGD251 WASHER-TOP LOADING
Amana LGD251 DRYER- GAS
Amana LGD312 DRYER- GAS
Amana LGD32AW DRYER- GAS
Amana LGD451 WASHER-TOP LOADING
Amana LGD451 DRYER- GAS
Amana LGD512 DRYER- GAS
Amana LGD57AW DRYER- GAS
Amana LGD65AW DRYER- GAS
Amana LGD851 WASHER-TOP LOADING
Amana LGD851 DRYER- GAS
Amana LGD912 DRYER- GAS
Amana LGD951 WASHER-TOP LOADING
Amana LGD951 DRYER- GAS
Whirlpool LGE9848BQ1 GAS DRYER
Whirlpool LGE9848BQ2 GAS DRYER
Whirlpool LGE9848BZ1 GAS DRYER
Whirlpool LGE9848BZ2 GAS DRYER
Frigidaire LGEF3031KBA ELECTRIC RANGE
Frigidaire LGEF3031KBB ELECTRIC RANGE
Frigidaire LGEF3031KBC ELECTRIC RANGE
Frigidaire LGEF3031KMA ELECTRIC RANGE
Frigidaire LGEF3031KMB ELECTRIC RANGE
Frigidaire LGEF3031KWA ELECTRIC RANGE
Frigidaire LGEF3031KWB ELECTRIC RANGE
Frigidaire LGEF3031KWC ELECTRIC RANGE
Frigidaire LGEF3033KBA ELECTRIC RANGE
Frigidaire LGEF3033KBB ELECTRIC RANGE
Frigidaire LGEF3033KBC ELECTRIC RANGE
Frigidaire LGEF3033KBD ELECTRIC RANGE
Frigidaire LGEF3033KBE ELECTRIC RANGE
Frigidaire LGEF3033KQA ELECTRIC RANGE
Frigidaire LGEF3033KQB ELECTRIC RANGE
Frigidaire LGEF3033KQC ELECTRIC RANGE
Frigidaire LGEF3033KQD ELECTRIC RANGE
Frigidaire LGEF3033KQE ELECTRIC RANGE
Frigidaire LGEF3033KWA ELECTRIC RANGE
Frigidaire LGEF3033KWB ELECTRIC RANGE
Frigidaire LGEF3033KWC ELECTRIC RANGE
Frigidaire LGEF3033KWD ELECTRIC RANGE
Frigidaire LGEF3033KWE ELECTRIC RANGE
  #2 (permalink)
Old 09-02-2013, 08:05 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Duct assembly on a dishwasher never heard of it? Do you mean the steam vent in the front or side of the unit up top? Take a picture from where it's coming from or look at the parts schematic on your unit here and identify the proper part it's coming from.
Parts for Frigidaire LGBD2431LF0A Dishwasher - AppliancePartsPros.com
  #3 (permalink)
Old 09-03-2013, 08:00 AM
Junior Member
Default part 13
I am not a repairman.As far as calling it the duct assembly, I was just using the term listed under: door parts, item 13. yes it seems like what you are calling the vent. It may actually be leaking from the bottom door seal. but the funny thing I cant figure out is that it doesn't leak until its near the end of a washing cycle (about 25-35 minutes into the cycle)
  #4 (permalink)
Old 09-03-2013, 04:22 PM
Senior Member
Default
Your vent may be clogged not allowing the steam to come out the front i had one today that was completely clogged so instead of going out the front or side of unit as it was designed it'll find somewhere else to go especially if it has a gasket that's worn is into the door. Then later on in in the cycle when it's working all that condensation will drip down the inside of the door panel and look like a tub leak. Anyways here's some video's to help you figure it out. Best thing for you to do is remove the front panel piece part #20 on the diagram and leave the rest and close the door and test it you'll be able to see where the unit is leaking from exactly. Also after your done make sure your unit is level from right to left and front to back otherwise it will leak again in time. Good luck
http://www.appliancepartspros.com/do...d2431lf0a.html
dishwasher leaking - YouTube
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
AIr duct assembly gwhitam Dryer Repair 0 01-08-2012 11:07 AM
how to replace front air duct assembly davarg Dryer Repair 0 11-01-2010 07:33 AM
Assembly heater duct gvzh39 Dryer Repair 3 08-16-2010 06:30 AM
assembly heater duct gvzh39 Dryer Repair 1 08-16-2010 06:27 AM
Duct Inlet Assembly stanco39 Dryer Repair 4 12-04-2009 01:03 PM
