Discuss
Water in Drain Base and mold buildup
 in
Dishwasher Repair
Hi, a few questions about cleaning and maintaining my 66513443k901 dishwasher: 1. The door filter/air escape area always gets moldy
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Water in Drain Base and mold buildup
  #1 (permalink)
Old 09-02-2013, 11:30 AM
Junior Member
tonydehnke is on a distinguished road
Question Water in Drain Base and mold buildup
Model Number: 66513443k901   Brand: Kenmore   Age: 1 - 5 years
1. The door filter/air escape area always gets moldy and slimy - it's almost like it doesn't vent or dry properly - can this be fixed or modified so it isn't as bad?
2. When I remove the filter at the bottom of the dishwasher (Filter-Pump - circular filter about 10" across part #AP3130690 i think), under it there is what I think is a lot of standing water sitting in the Drain base - is that normal? See image
3. How often should the filter-pump part be replaced (Part #AP3130690 I believe)?
4. Should there be a build up of goop and muk in that area below the filter-pump?
This is the diagram for my dishwasher as far as I can tell: http://www.*************************...&prst=&shdMod=
Thanks!
Related Models
Kenmore 66513443K901 UNDERCOUNTER DISHWASHER
Kenmore 66513444K900 DISHWASHER
Kenmore 66513444K901 UNDERCOUNTER DISHWASHER
Kenmore 66513449K900 DISHWASHER
Kenmore 66513449K901 UNDERCOUNTER DISHWASHER
Kenmore 66513452K900 DISHWASHER
Kenmore 66513452K901 PORTABLE DISHWASHER
Kenmore 66513452K902 UNDERCOUNTER DISHWASHER
Kenmore 66513453K901 PORTABLE DISHWASHER
Kenmore 66513453K902 UNDERCOUNTER DISHWASHER
Kenmore 66513459K900 DISHWASHER
Kenmore 66513459K901 PORTABLE DISHWASHER
Kenmore 66513459K902 UNDERCOUNTER DISHWASHER
Kenmore 66513462K900 DISHWASHER
Kenmore 66513462K901 UNDERCOUNTER DISHWASHER
Kenmore 66513462K902 UNDERCOUNTER DISHWASHER
Kenmore 66513462K903 UNDERCOUNTER DISHWASHER
Kenmore 66513463K900 DISHWASHER
Kenmore 66513463K901 UNDERCOUNTER DISHWASHER
Kenmore 66513463K902 UNDERCOUNTER DISHWASHER
Kenmore 66513463K903 UNDERCOUNTER DISHWASHER
Kenmore 66513469K900 DISHWASHER
Kenmore 66513469K901 UNDERCOUNTER DISHWASHER
Kenmore 66513469K902 UNDERCOUNTER DISHWASHER
Kenmore 66513469K903 UNDERCOUNTER DISHWASHER
Kenmore 66513472K900 DISHWASHER
Kenmore 66513472K901 UNDERCOUNTER DISHWASHER
Kenmore 66513472K902 UNDERCOUNTER DISHWASHER
Kenmore 66513473K900 DISHWASHER
Kenmore 66513473K901 UNDERCOUNTER DISHWASHER
Kenmore 66513473K902 UNDERCOUNTER DISHWASHER
Kenmore 66513479K900 DISHWASHER
Kenmore 66513479K901 UNDERCOUNTER DISHWASHER
Kenmore 66513479K902 UNDERCOUNTER DISHWASHER
Kenmore 66513482K900 DISHWASHER
Kenmore 66513482K901 UNDERCOUNTER DISHWASHER
Kenmore 66513482K902 DISHWASHER
Kenmore 66513482K903 UNDERCOUNTER DISHWASHER
Kenmore 66513483K900 DISHWASHER
Kenmore 66513483K901 UNDERCOUNTER DISHWASHER
Kenmore 66513483K902 DISHWASHER
Kenmore 66513483K903 UNDERCOUNTER DISHWASHER
Kenmore 66513484K900 DISHWASHER
Kenmore 66513484K901 UNDERCOUNTER DISHWASHER
Kenmore 66513484K902 DISHWASHER
Kenmore 66513484K903 UNDERCOUNTER DISHWASHER
Kenmore 66513489K900 DISHWASHER
Kenmore 66513489K901 UNDERCOUNTER DISHWASHER
Kenmore 66513489K902 DISHWASHER
Kenmore 66513489K903 UNDERCOUNTER DISHWASHER
Kenmore 66513492K600 DISHWASHER
Kenmore 66513499K600 DISHWASHER
Kenmore 6651350190 COMPACTOR
Kenmore 6651350191 COMPACTOR
Kenmore 6651350192 COMPACTOR
Kenmore 6651350193 COMPACTOR
Kenmore 6651350194 COMPACTOR
Kenmore 6651350195 COMPACTOR
Kenmore 6651350196 COMPACTOR
Kenmore 6651350590 COMPACTOR
Kenmore 6651350591 COMPACTORS
Kenmore 6651350592 COMPACTOR
Kenmore 6651350593 COMPACTOR
Kenmore 6651350594 COMPACTORS
Kenmore 6651350595 COMPACTOR
Kenmore 6651350596 COMPACTOR
Kenmore 66513552K700 DISHWASHER
Kenmore 66513559K700 DISHWASHER
Kenmore 66513562K700 DISHWASHER
Kenmore 66513569K700 DISHWASHER
Kenmore 66513572K700 DISHWASHER
Kenmore 66513573K700 DISHWASHER
Kenmore 66513579K700 DISHWASHER
Kenmore 66513582K700 DISHWASHER
Kenmore 66513583K700 DISHWASHER
Kenmore 6651358550 TRASH COMPACTOR
Kenmore 6651358551 TRASH COMPACTOR
Kenmore 66513589K700 DISHWASHER
Kenmore 66513592K600 Dishwasher
Kenmore 66513593K600 Dishwasher
Kenmore 66513594K600 Dishwasher
Kenmore 66513599K600 Dishwasher
Kenmore 66513601790 COMPACTOR
Kenmore 66513603000 COMPACTORS
Kenmore 66513604000 COMPACTORS
Kenmore 66513605790 COMPACTOR
Kenmore 66513608790 COMPACTOR
Kenmore 66513612100 COMPACTORS
Kenmore 66513612101 COMPACTOR
Kenmore 66513612102 COMPACTOR
Kenmore 66513613100 COMPACTORS
Kenmore 66513613101 COMPACTOR
Kenmore 66513613102 COMPACTOR
Kenmore 66513614100 COMPACTORS
Kenmore 66513614101 COMPACTOR
Kenmore 66513614102 COMPACTOR
Kenmore 66513619100 COMPACTORS
Kenmore 66513619101 COMPACTOR
Kenmore 66513619102 COMPACTOR
Kenmore 66513632K900 DISHWASHER
Kenmore 66513632K901 DISHWASHER
Kenmore 66513632K902 UNDERCOUNTER DISHWASHER
Kenmore 66513632K903 UNDERCOUNTER DISHWASHER
Kenmore 66513633100 COMPACTOR
Kenmore 66513633101 COMPACTOR
Kenmore 66513633K900 DISHWASHER
Kenmore 66513633K901 DISHWASHER
Kenmore 66513633K902 UNDERCOUNTER DISHWASHER
Kenmore 66513633K903 UNDERCOUNTER DISHWASHER
Kenmore 66513639K900 DISHWASHER
Kenmore 66513639K901 DISHWASHER
Kenmore 66513639K902 UNDERCOUNTER DISHWASHER
Kenmore 66513639K903 UNDERCOUNTER DISHWASHER
Kenmore 66513672K600 DISHWASHER
Kenmore 66513672K601 DISHWASHER
Kenmore 66513672K602 DISHWASHER
Kenmore 66513673K600 DISHWASHER
Kenmore 66513673K601 DISHWASHER
Kenmore 66513673K602 DISHWASHER
Kenmore 66513679K600 DISHWASHER
  #2 (permalink)
Old 09-02-2013, 01:42 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
A moldy and gunky bottom is normal in most cases yours doesn't look that bad. Make sure your check balls and drain area are clean and that if your drain hose has a flap or check valve that the flap is in tact or replace that helps water from coming back up in unit and being stagnant. Ohm check the heating element and if you have an amp clamp mulitmeter enter diagnostic mode and when it gets to the heating element working it should have around 6-8amps if not there's something wrong with the heating circuit this will cause a gunky dishwasher also. Cycle the dishwasher empty on the hottest setting and use 2 cups of vinegar once month in your dishwasher to help with cleaning the unit. Also realize dishwashers are not dishwashers they are sanitizers it's your job to clean the dishes not the machine so the dirtier the dishes you put it the less of a life your machine will have and the more gunk buildup. Voltage and ohm test your steam exit motor if you think it's malfunctioning during diagnostic. Good luck
  #3 (permalink)
Old 09-02-2013, 02:47 PM
Junior Member
Default
Thanks, we've cleaned out the bottom and will keep an eye on it.
Attached is a picture of the filter unit, you can see one side looks clean (bottom left of picture) and the right side and top side is very dirty - enough that it looks like it is time to replace it. Is this normal, or dirty enough to replace at this time?
Totally understand what your saying about cleaning.. that said to sanitize something it seems odd to leave that much guk and water at the base as part of normal operations
There is no motor or fan in the steam vent that I can see inside the door or in the diagrams for the door - maybe that is the problem - no fan to help move the air?
  #4 (permalink)
Old 09-02-2013, 03:36 PM
Senior Member
Default
Your unit may not have that exhaust fan some older units don't.....also check your water heater and make sure its set to 120 degrees or above that's what dishwashers require. Also turn on the kitchen sink till you get hot water all the way to that location of your house then turn on dishwasher that helps also.
  #5 (permalink)
Old 09-02-2013, 03:37 PM
Junior Member
Default
Thanks, the hot water is good and we run the water prior to operation already.
Any thoughts on that filter unit?
  #6 (permalink)
Old 09-02-2013, 03:41 PM
Senior Member
Default
Looks fine to me that's not bad at all to be honest...............Avoid using pod or powder detergent use gel type also don't use brands like Sun, Purex, Kirkland, Arm and hammer or any real cheap brands.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice maker puts to much water into mold Eagleone Refrigerator & Freezer Repair 0 07-07-2012 11:32 AM
Water and ice taste like mildew/mold stratocruiser377 Refrigerator & Freezer Repair 0 08-19-2011 09:57 PM
Flushing mold from in refrigerator water line wits end Refrigerator & Freezer Repair 2 08-09-2011 04:01 AM
Permanent Fix for Debris buildup in drain JerrytheGreat Dishwasher Repair 1 08-08-2011 02:31 AM
GE Profile Refrigerator Mold in Water Dispenser Brucerb Refrigerator & Freezer Repair 0 06-10-2010 01:57 PM
