Register | FAQ's | New Posts | Today's Posts | Extras |
» GE Nautilus will not drain |
![]() Model Number: GSD3960L00SS Brand: GE Age: 5 - 10 years
![]() Help. My GE Nautilus won't drain at all (not even partially) and after all the troubleshooting I still can't get it to drain. Here are the steps that I have already done: I first removed the sump filter inside the machine and did not notice any material that caused any obstructions. I then checked for a blocked drain pipe by unscrewing it at the drain point under the sink and found nothing there. Next I removed the kick plate and checked that the Selenoid underneath would pull down when the machine would go into the drain phase. I even removed the drain pipe at the machine to make sure there was not a plug at that end with which there was not. I also checked the Piston and Nut which is located at the rear of the unit and has to be unscrewed. That was also ok. I can't think of anything else. Am I missing something? Any help is appreciated. Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() Hey Humboldt I ordered a new drain Selenoid so I hope that clears it up before checking the voltage on the old one. Thanks for the reply.
![]() Hey Humboldt what would be a good voltage read on the Selenoid if its running in good? Only reason I ask is if I run into this problem again I'd like to know if the Selenoid is running good and then I can focus on some other problem. Again thanks for the replies.
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
ge nautilus doesn't drain | pdaly28 | Dishwasher Repair | 7 | 06-25-2010 06:30 PM |
GE Nautilus Dishwasher Won't Drain | gunnermel | Dishwasher Repair | 1 | 10-14-2009 06:17 PM |
Ge Nautilus Does Not Drain | GREBNOV | Dishwasher Repair | 1 | 02-07-2009 08:17 PM |
GE Nautilus Does not drain. | ckengland | Dishwasher Repair | 1 | 12-16-2008 09:41 AM |
GE Nautilus won't drain | novice repair man | Dishwasher Repair | 4 | 06-09-2008 06:27 AM |
