Discuss
new motor/pump won't run more than 5 secs
 in
Dishwasher Repair
I have model GU980SCG2 and just replaced the motor/pump (#W10428168). I hooked everything back up but it will not run
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » new motor/pump won't run more than 5 secs
  #1 (permalink)
Old 08-25-2013, 12:26 PM
Junior Member
GLS0628 is on a distinguished road
Default new motor/pump won't run more than 5 secs
Model Number: GU980SCGS2   Brand: Whirlpool   Age: More than 10 years
I have model GU980SCG2 and just replaced the motor/pump (#W10428168). I hooked everything back up but it will not run more than about 5 secs without shutting off. I hit the quick wash button and it fills with water. Then it turns water off and the the motor starts and runs for about 5 secs and then clicks off. The washing light remains lite. Then it goes about 3 minutes and trys again. Same thing happens. The timing is exact every time. I timed it during 2 cycles of doing this. The motor ran for 4.7 secs and 4.8 secs. The time between running was 3:09 and 3:10 secs. It is like something is telling the motor to stop. Also when I try to drain the machine the drain/cancel light comes on and the motor makes a humming noise like it wants to start but can't. Then shortly after it makes a click and goes quite. The drain/cancel light remains lite.
It seams like the motor want starts to run so I don't see it being the new motor. Any suggestions for me to look at or test?
thanks,
Greg
Related Models
Whirlpool GU980SCGS2 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGS3 DISHWASHER
Whirlpool GU980SCGT2 DISHWASHER
Whirlpool GU980SCGT3 DISHWASHER
Whirlpool GU980SCGZ0 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGZ1 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGZ2 UNDERCOUNTER DISHWASHER
Maytag GV1110PRW RANGE- F/S STD GAS
Admiral GV1226NXEW FREEZER- VERTICAL
Admiral GV1726NXEW FREEZER- VERTICAL
Hoover GV3177WUA RANGE- F/S STD GAS
Hoover GV3177WUW RANGE- F/S STD GAS
Hoover GV3177WUW5 RANGE- F/S STD GAS
Maytag GV3277XUA RANGE- F/S STD GAS
Maytag GV3277XUW RANGE- F/S STD GAS
Hoover GV3531WUA RANGE- F/S STD ELE
Hoover GV3531WUW RANGE- F/S STD ELE
General Electric GVSR1060H7WW WASHER
General Electric GVSR1060H9WW WASHER
General Electric GVSR1080H8WW WASHER
Whirlpool GVW9959KL0 WASHER
Whirlpool GVW9959KL1 WASHER - DIRECT DRIVE
Whirlpool GVW9959KL2 WASHER - DIRECT DRIVE
Whirlpool GVW9959KL3 AUTOMATIC WASHER
Whirlpool GVW9959KQ0 WASHER
Whirlpool GVW9959KQ1 WASHER - DIRECT DRIVE
Whirlpool GVW9959KQ2 WASHER - DIRECT DRIVE
Whirlpool GVW9959KQ3 AUTOMATIC WASHER
Whirlpool GVW9959KT0 WASHER
Whirlpool GVW9959KT1 WASHER - DIRECT DRIVE
Whirlpool GVW9959KT2 WASHER - DIRECT DRIVE
Whirlpool GVW9959KT3 AUTOMATIC WASHER
Maytag GW18F1A WASHER-TOP LOADING
Maytag GW18F1H WASHER-TOP LOADING
Maytag GW18F1W WASHER-TOP LOADING
Maytag GW18F2A WASHER-TOP LOADING
Maytag GW18F2H WASHER-TOP LOADING
Maytag GW18F2W WASHER-TOP LOADING
Maytag GW18G1A WASHER-TOP LOADING
Maytag GW18G1HW WASHER-TOP LOADING
Maytag GW18G1WW WASHER-TOP LOADING
Maytag GW20F6A WASHER-TOP LOADING
Maytag GW20F6H WASHER-TOP LOADING
Maytag GW20F6W WASHER-TOP LOADING
Frigidaire GW30SPEA2 Wwh(v1) / Electric Range
Frigidaire GW30SPED1 Wwh(v2) / Electric Range
Frigidaire GW30SPEW1 Wwh(v1) / Electric Range
Frigidaire GW30SPEW2 Wwh(v2) / Electric Range
Whirlpool GW395LEGB0 GAS RANGE
Whirlpool GW395LEGB1 GAS RANGE
Whirlpool GW395LEGB2 GAS RANGE
Whirlpool GW395LEGB3 GAS RANGE
Whirlpool GW395LEGB4 GAS RANGE
Whirlpool GW395LEGB5 GAS RANGE
Whirlpool GW395LEGB6 GAS RANGE
Whirlpool GW395LEGQ0 GAS RANGE
Whirlpool GW395LEGQ1 GAS RANGE
Whirlpool GW395LEGQ2 GAS RANGE
Whirlpool GW395LEGQ3 GAS RANGE
Whirlpool GW395LEGQ4 GAS RANGE
Whirlpool GW395LEGQ5 GAS RANGE
Whirlpool GW395LEGQ6 GAS RANGE
Whirlpool GW395LEGT2 GAS RANGE
Whirlpool GW395LEGT3 GAS RANGE
Whirlpool GW395LEGT4 GAS RANGE
Whirlpool GW395LEGT5 GAS RANGE
Whirlpool GW395LEGT6 GAS RANGE
Whirlpool GW395LEGZ0 GAS RANGE
Whirlpool GW395LEGZ1 GAS RANGE
Whirlpool GW395LEGZ2 GAS RANGE
Whirlpool GW395LEGZ3 GAS RANGE
Whirlpool GW395LEPB00 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB01 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB02 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB03 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB04 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB05 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ00 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ01 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ02 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ03 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ04 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ05 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS00 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS01 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS02 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS03 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS04 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS05 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT00 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT01 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT02 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT03 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT04 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT05 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW397LXUB0 30" Gas Slide-In
Whirlpool GW397LXUB05 30" GAS SLIDE-IN
Whirlpool GW397LXUB06 30" GAS SLIDE-IN RANGE
Whirlpool GW397LXUB1 30" GAS SLIDE-IN
Whirlpool GW397LXUB5 30" GAS SLIDE-IN
Whirlpool GW397LXUQ0 30" Gas Slide-In
Whirlpool GW397LXUQ06 30" GAS SLIDE-IN
Whirlpool GW397LXUQ1 30" GAS SLIDE-IN
Whirlpool GW397LXUQ6 30" GAS SLIDE-IN
Whirlpool GW397LXUS0 30" Gas Slide-In
Whirlpool GW397LXUS05 30" GAS SLIDE-IN
Whirlpool GW397LXUS06 30" GAS SLIDE-IN RANGE
Whirlpool GW397LXUS1 30" GAS SLIDE-IN
Whirlpool GW397LXUS5 30" GAS SLIDE-IN
Whirlpool GW397LXUT0 30" Gas Slide-In
Whirlpool GW397LXUT05 30" GAS SLIDE-IN
Whirlpool GW397LXUT06 30" GAS SLIDE-IN
Whirlpool GW397LXUT1 30" GAS SLIDE-IN
Whirlpool GW397LXUT5 30" GAS SLIDE-IN
Whirlpool GW399LXUB0 30" Gas Slide-In
Whirlpool GW399LXUB05 30" GAS SLIDE-IN
Whirlpool GW399LXUB06 30" GAS SLIDE-IN RANGE
Whirlpool GW399LXUB1 30" Gas Slide-In
Whirlpool GW399LXUB5 30" Gas Slide-In
Whirlpool GW399LXUQ0 30" Gas Slide-In
  #2 (permalink)
Old 08-25-2013, 02:56 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Hook up your voltmeter to the motors your testing and if you see it drop from 120v to nothing then it's a problem with your harness and or wire connections or the main board..........also check your motors (pump and sump) for continuity, you may have gotten a bad part perhaps.
  #3 (permalink)
Old 08-25-2013, 04:59 PM
Junior Member
Default
Can you give me a little details on your 2 suggestions?
Greg
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
need part # for motor greese cap between pump and motor bones0 Washer Repair 1 03-07-2011 07:21 PM
Noisy Whirlpool Dishwasher: Replace just motor or whole pump&motor mdion Dishwasher Repair 7 02-28-2011 02:31 PM
Whirlpool dishwasher parts - replace motor or motor AND pump? dishwasher hums Dishwasher Repair 4 01-04-2011 05:57 AM
water sprays out for about 2 secs sleddin97 Dishwasher Repair 0 09-09-2010 10:54 AM
Wash motor won't start, bad pump motor capacitor? 65skyturbo Dishwasher Repair 0 07-17-2010 12:58 PM
