cambrosn
#1 Posted : Friday, August 23, 2013 6:41:46 PM(UTC)
cambrosn
After listening to my GE dishwasher rattle during the drain cycle for a few weeks, I decided to look into it. I guess I neglected the machine for a while because the drain was about 75% clogged and I use a bunch of Q-Tips cleaning out the crevasses inside the dishwasher.
At first I thought it was the drain pump starving itself due to the clogged drain, but after cleaning it, the sound remains. It's a fairly loud rattle (like something is loose) when it's between cycles and draining. Otherwise, it's nothing a whole lot more than you'd expect from a 2-1/2 year old budget dishwasher.
After doing a little research, I think it may be a rattling impeller (#430) or rattle in the pump drain assembly (#325). Any ideas?
Thanks,
Chris
HumboldtRepairMan
#2 Posted : Saturday, August 24, 2013 8:43:10 AM(UTC)
HumboldtRepairMan
Disconnect the drain hose from the sink and take a wet vac and suck the line out you may have something inside the drain pipe. Then test if the rattle went away you solved the problem. It if didn't eliminate the noise detach the drain pump from under the unit and physically examine the drain pump and surrounding area's from underneath unit and within the unit at the base of the sump pump. Also with some of these cheap models the drain pump hangs down with no real stable support and sometimes you can get away with take a piece of wood and wedging it under the drain pump to eliminate excessive noise. Good luck
