| » blinking control panel rinse cycle |
Model Number: KUDS01DJSB0 Brand: Kitchen Aid Age: 1 - 5 years
The top panel is all off but the RINSE button is blinking. When you hit the cancel button 2 dashes apear and then disapear when hit again. If the door is closed real hard it might stat to run or run for half the cycle and then stop. I have power to the unit ans I assume the internal fuse #6 is not blown. I guess that I am trying to confirm that replacing the Control Panel #11 is the right move.
Mr Howdy |
I had the same problem Mr. Howdy..
Than I found someone on here that told me what to do and it worked. Hopefully what i a gonna tell ya will work also. I pressed cancel than opened the door. within 3 seconds. I hit the HIgh temp scrub than the energy saver than repeat it again. If it does work all the lights will light up . close the door and the rinse light should go off.. Good luck this site is great for helping people out...let me know if this works. Julie |
| Display Modes | |
| Runs rinse cycle all the way through the spin cycle | hebirdseye | Washer Repair | 1 | 01-20-2008 06:10 PM |
| GE Washer will not spin on rinse cycle | mguy77 | Washer Repair | 1 | 01-15-2008 07:37 PM |
| washer keeps repeating the rinse cycle | hiltonacres | Washer Repair | 2 | 12-13-2007 08:22 PM |
| no water on rinse cycle | c4cdlm | Washer Repair | 3 | 12-12-2007 04:56 PM |
| Dishwasher skips the wash cycle and stops at the rinse cycle | jasporo | Dishwasher Repair | 1 | 11-16-2007 06:12 PM |
