alentz
#1 Posted : Wednesday, August 7, 2013 6:34:21 PM(UTC)
alentz
Door counter balance broke allowing the door to drop hard against it's stops.:eek: Got the parts to repair the counter balance, installed and all is well except now when trying to use the regular wash cycle, the cancel light blinks indicating a fault. Tried running on heavy duty with the same results. The only cycle it will run on is the light china cycle. It will run all the way through without fail although does not clean the dishes properly unless washed by hand.
What could the problem be and how would I go about checking what the fault is?
In researching the faults could be a bad heating element (which was changed within the last 6 months) or the drain pump which works just fine on the light cycle so I assume that is not the problem.
Any ideas would be appreciated.:)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
LG dishwasher bE Bubble Error (Dishwasher Repair)
by Guest 2/13/2024 10:58:29 AM(UTC)
Frigidaire dishwasher 2nd water inlet valve fails (Dishwasher Repair)
by Guest 2/13/2024 3:32:15 AM(UTC)
Dishwasher fills and drains only. Does not go through the wash and rinse cycle (Dishwasher Repair)
by Guest 2/11/2024 6:26:48 AM(UTC)
Maytag dishwasher model MDB4949SKZ1 (Dishwasher Repair)
by thepontif 2/3/2024 11:15:46 AM(UTC)
#DW80F600UTS Samsung Dishwasher High Temperature Heating Error (Dishwasher Repair)
by Guest 1/24/2024 6:35:24 AM(UTC)
GE Dishwasher GDF620HMJ2ES (Dishwasher Repair)
by lou@officenerd.com 1/14/2024 3:32:20 PM(UTC)
Clean light flashing 7 times: dishwasher run (Dishwasher Repair)
by Guest 1/14/2024 9:56:27 AM(UTC)
KDTE554CSS3 Dishwasher (Dishwasher Repair)
by olderwhite@yahoo.com 1/13/2024 10:34:56 AM(UTC)
Dishwasher electrical help (Dishwasher Repair)
by Guest 1/11/2024 4:35:37 PM(UTC)
Siemens dishwasher pump keeps running (Dishwasher Repair)
by Fweigel 12/30/2023 4:35:28 AM(UTC)
Maytag dishwasher drain always runs? (Dishwasher Repair)
by Guest 12/15/2023 6:04:35 PM(UTC)
