Discuss
No water pressure
 in
Dishwasher Repair
Dishwasher worked fine. Then we decided to put in a new floor. So I had to pull the dishwasher out.
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » No water pressure
  #1 (permalink)
Old 07-28-2013, 05:16 PM
Junior Member
walter3ca is on a distinguished road
Default No water pressure
Model Number: HM100   Brand: Maytag   Age: More than 10 years
Dishwasher worked fine. Then we decided to put in a new floor. So I had to pull the dishwasher out. When I put the dishwasher back in, it would suddenly not drain. I pulled the breather cap off and I'm just getting a bubble of water. I stripped the insides down to the impeller and it seems fine. I blew into the inlet hose and it bubbled in the bottom of the dishwasher. My best guess is that the hose is either too high or not high enough. There are no kinks in it.
Related Models
Maytag HM3301HMSE3 ELECTRIC WATER HEATER
Maytag HM3301HMSE4 ELECTRIC WATER HEATER
Maytag HM3302HMSE3 ELECTRIC WATER HEATER
Maytag HM3302HMSE4 ELECTRIC WATER HEATER
Maytag HM330DHMSE3 ELECTRIC WATER HEATER
Maytag HM330DHMSE4 ELECTRIC WATER HEATER
Maytag HM330NHDST GAS WATER HEATER
Maytag HM330NHMT GAS WATER HEATER
Maytag HM330SHMSE3 ELECTRIC WATER HEATER
Maytag HM330SHMSE4 ELECTRIC WATER HEATER
Maytag HM3401HMSE3 ELECTRIC WATER HEATER
Maytag HM3401HMSE4 ELECTRIC WATER HEATER
Maytag HM3402HMSE3 ELECTRIC WATER HEATER
Maytag HM3402HMSE4 ELECTRIC WATER HEATER
Maytag HM340DHMSE3 ELECTRIC WATER HEATER
Maytag HM340DHMSE4 ELECTRIC WATER HEATER
Maytag HM340NHDST GAS WATER HEATER
Maytag HM340NHMT GAS WATER HEATER
Maytag HM340SHMSE3 ELECTRIC WATER HEATER
Maytag HM340SHMSE4 ELECTRIC WATER HEATER
Maytag HM3502HMTE3 ELECTRIC WATER HEATER
Maytag HM3502HMTE4 ELECTRIC WATER HEATER
Maytag HM350NHDST GAS WATER HEATER
Maytag HM350NHMT GAS WATER HEATER
Maytag HM3522HMTE3 ELECTRIC WATER HEATER
Maytag HM3522HMTE4 ELECTRIC WATER HEATER
Maytag HM352DHMTE3 ELECTRIC WATER HEATER
Maytag HM352DHMTE4 ELECTRIC WATER HEATER
 HMC036KDT1 Air Conditioner
 HMH012KD1 Air Conditioner
 HMH024KD1 Air Conditioner
General Electric HMV24CEWABB Gas range
General Electric HMV24CEWAN Gas range
General Electric HMV24CEWEBB Gas range
General Electric HMV24CEWEN Gas range
Maytag HN41240P GAS WATER HEATER
Maytag HN41240PCAN GAS WATER HEATER
Maytag HN41240X GAS WATER HEATER
Maytag HN41240XCAN GAS WATER HEATER
Maytag HN41250P GAS WATER HEATER
Maytag HN41250PCAN GAS WATER HEATER
Maytag HN41250Q GAS WATER HEATER
Maytag HN41250QCAN GAS WATER HEATER
Maytag HN41250V GAS WATER HEATER
Maytag HN41250VCAN GAS WATER HEATER
Maytag HN41250VCANZ GAS WATER HEATER
Maytag HN41250VZ GAS WATER HEATER
Maytag HN41250X GAS WATER HEATER
Maytag HN41250XCAN GAS WATER HEATER
Maytag HN41275P GAS WATER HEATER
Maytag HN41275PCANZ GAS WATER HEATER
Maytag HN41275PZ GAS WATER HEATER
Maytag HN41275Q GAS WATER HEATER
Maytag HN41275QCAN GAS WATER HEATER
Maytag HN4830T971 GAS WATER HEATER
Maytag HN4840S971 GAS WATER HEATER
Maytag HN4840T971 GAS WATER HEATER
Maytag HN4850T971 GAS WATER HEATER
Maytag HN4875S980 GAS WATER HEATER
Maytag HN4930T GAS WATER HEATER
Maytag HN4930TCAN GAS WATER HEATER
Maytag HN4940S GAS WATER HEATER
Maytag HN4940SCAN GAS WATER HEATER
Maytag HN4940T GAS WATER HEATER
Maytag HN4940TCAN GAS WATER HEATER
Maytag HN4950S GAS WATER HEATER
Maytag HN4950SCAN GAS WATER HEATER
Maytag HN4950T GAS WATER HEATER
Maytag HN4950TCAN GAS WATER HEATER
Maytag HN4975S GAS WATER HEATER
Maytag HN4975SCAN GAS WATER HEATER
Maytag HN4X40P980 GAS WATER HEATER
Maytag HN4X40X960 GAS WATER HEATER
Maytag HN4X40X960CGA GAS WATER HEATER
Maytag HN4X50P980 GAS WATER HEATER
Maytag HN4X50Q960 GAS WATER HEATER
Maytag HN4X50Q960CGA GAS WATER HEATER
Maytag HN4X50V980 GAS WATER HEATER
Maytag HN4X50X960 GAS WATER HEATER
Maytag HN4X50X960CGA GAS WATER HEATER
Maytag HN51240P GAS WATER HEATER
Maytag HN51240PCAN GAS WATER HEATER
Maytag HN51240X GAS WATER HEATER
Maytag HN51240XCAN GAS WATER HEATER
Maytag HN51250P GAS WATER HEATER
Maytag HN51250PCAN GAS WATER HEATER
Maytag HN51250Q GAS WATER HEATER
Maytag HN51250QCAN GAS WATER HEATER
Maytag HN51250V GAS WATER HEATER
Maytag HN51250VCAN GAS WATER HEATER
Maytag HN51250VCANZ GAS WATER HEATER
Maytag HN51250VZ GAS WATER HEATER
Maytag HN51250X GAS WATER HEATER
Maytag HN51250XCAN GAS WATER HEATER
Maytag HN51275P GAS WATER HEATER
Maytag HN51275PCANZ GAS WATER HEATER
Maytag HN51275PZ GAS WATER HEATER
Maytag HN51275Q GAS WATER HEATER
Maytag HN51275QCAN GAS WATER HEATER
Maytag HN5830T971 GAS WATER HEATER
Maytag HN5840S971 GAS WATER HEATER
Maytag HN5840T971 GAS WATER HEATER
Maytag HN5850T971 GAS WATER HEATER
Maytag HN5875S980 GAS WATER HEATER
Maytag HN5930T GAS WATER HEATER
Maytag HN5930TCAN GAS WATER HEATER
Maytag HN5940S GAS WATER HEATER
Maytag HN5940SCAN GAS WATER HEATER
Maytag HN5940T GAS WATER HEATER
Maytag HN5940TCAN GAS WATER HEATER
Maytag HN5950S GAS WATER HEATER
Maytag HN5950SCAN GAS WATER HEATER
Maytag HN5950T GAS WATER HEATER
Maytag HN5950TCAN GAS WATER HEATER
Maytag HN5975S GAS WATER HEATER
Maytag HN5975SCAN GAS WATER HEATER
Maytag HN5X40P980 GAS WATER HEATER
Maytag HN5X40X960 GAS WATER HEATER
Maytag HN5X40X960CGA GAS WATER HEATER
Maytag HN5X50P980 GAS WATER HEATER
  #2 (permalink)
Old 07-28-2013, 05:19 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Did you remember to turn the valve back on for the water supply? also did you turn off the breaker while moving it to prevent shorts?
  #3 (permalink)
Old 07-29-2013, 06:21 AM
Junior Member
Default
I unplugged it and I did turn off the water.
  #4 (permalink)
Old 07-29-2013, 04:28 PM
Senior Member
Default
When you say breather cap do you mean aerator? DId you check that for debris inside the cap? That's a common problem with no drain issues because it doesn't take much to clog those. Also some drain hoses have flaps near the motor mount on the hose that prevents backflow sometimes those flaps break off and get stuck in the hose..........Check the drain pump for 120v to the unit after you hit cancel drain if you have 120v and no hum from the motor it's a bad drain pump..........if the motor is humming and turning and working right you have a clog in your drain line or sump pump inside.
  #5 (permalink)
Old 07-29-2013, 07:28 PM
Junior Member
Default
My dishwasher is so old, it doesn't have any buttons. Just a dial.
  #6 (permalink)
Old 07-29-2013, 07:32 PM
Senior Member
Default
Your model number isn't correct your giving a model number to a lawn and garden piece of equipment.....if it's real old then it's probably a whole sump pump which has the drain and sump in one piece and in all honestly to replace that is probably close to just buying a new unit..........you can get dishwashers on sale for 3-400 best bet is to buy a new one if it's really old........
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
low water pressure sodboy1 Refrigerator & Freezer Repair 0 06-20-2011 10:46 AM
Not enough water pressure marshallfla Dishwasher Repair 7 05-11-2011 04:17 PM
Low water pressure to door after changing water filter kstokes Refrigerator & Freezer Repair 0 05-05-2011 09:55 AM
Motor humming and water comes but blades don't spin (water pressure problem?) mtheriault3 Dishwasher Repair 4 01-11-2009 04:18 PM
No water pressure Jim Brizz Dishwasher Repair 6 12-30-2008 06:13 PM
