Discuss
Quiet Partner II Dishwasher Not Working
 in
Dishwasher Repair
OK, Just one day the dishwasher stopped working. When I press the wash lights, at first nothing happened, then when
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Quiet Partner II Dishwasher Not Working
  #1 (permalink)
Old 07-25-2013, 02:00 PM
Junior Member
lhemenwayga is on a distinguished road
Angry Quiet Partner II Dishwasher Not Working
Brand: Whirlpool   Age: 1 - 5 years
OK, Just one day the dishwasher stopped working. When I press the wash lights, at first nothing happened, then when I hit Drain/Cancel, the Wash Cycle light came on and it sounds like it's trying to do something, but there's no water, nothing is happening.
I tried the normal wash/heat dry button trick mentioned in several other posts, but all that happened was the Soak & Scour light started coming on automatically when I hit the heated dry button. Now lights come on for each washing cycle light when I hit them, EXCEPT rinse.
However, NOTHING happens when I hit start. I only hear mechanical noises start up when I hit CANCEL/DRAIN. It's almost like it's trying to work in reverse. At no time is there water flow.
So, any thoughts? I'd love to find a solution.
Thanks!
lhemenwayga
  #2 (permalink)
Old 07-25-2013, 02:59 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Clean out the bottom of your unit all the way into the bottom dismantling sump parts check and make sure your sump is completely clean and check the drain pump of debris...if the drain pump is clogged or broken the unit may not function properly not allowing any water or functions to work.....once you check the drain pump make sure you have 120v to the drain pump......since you didn't leave a model number on your complaint i'm assuming you have a drain pump and sump pump separate make sure both have 120v going to them at appropriate times if you don't then i'm suspecting a bad main board or touchpad.........
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Quiet Partner - Buttons not Working DerekS Dishwasher Repair 8 07-10-2016 01:51 PM
Whirlpool Quiet Partner II not working mommaloca Dishwasher Repair 2 06-23-2012 10:00 AM
whirlpool quiet partner iii not working right gordy fowler Dishwasher Repair 1 08-17-2011 04:20 PM
Whirlpool Quiet Partner II not working gonzop067 Dishwasher Repair 1 06-29-2010 02:44 PM
Whirlpool Quiet Partner III not working rustythebailiff Dishwasher Repair 1 06-06-2009 05:58 AM
