Discuss
GE Pot Scrubber 650 (GSD650X-66WB
 in
Dishwasher Repair
Dishwasher is humming but will not start. When cycle put to short wash - water does come in. There are
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » GE Pot Scrubber 650 (GSD650X-66WB
  #1 (permalink)
Old 07-21-2013, 01:37 PM
Junior Member
rab28273 is on a distinguished road
Default GE Pot Scrubber 650 (GSD650X-66WB
Brand: GE   Age: More than 10 years
Dishwasher is humming but will not start. When cycle put to short wash - water does come in. There are posts about moving motor blades - but for the live of me - can't see any blades only the motor housing. Any ideas?
  #2 (permalink)
Old 07-21-2013, 03:01 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Disassemble the base of the unit from the inside and see if you have anything lodged in the sump or drain pump. You may have to pull dishwasher out from cabinet to check these components then go from there. Check the sump pump after it fills and see if you have 120v going to sump pump. Also check to see if your model has a diverter and if so make sure your diverter stops and doesn't constantly hum the whole time like it's trying to work.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ge Pot scrubber 700 dishwasher jet0524 Dishwasher Repair 7 03-03-2011 02:44 PM
GE GSD650X-68WB detergent dispenser won't release during cycle asapReps Dishwasher Repair 0 10-11-2009 05:52 PM
