My dishwasher runs and heats fine. However, the soap dispenser flap stays closed. The spring reacts fine if I manually release the flap. I have checked for anything preventing the door from opening, and can not see how anything could be in the way. This problem started after I had the fuse replaced that controls the door switch (control panel). Any help is appreciated.
