I order a new sump assembly from APP and while disassembling the old one I failed to note how the rubber tabs on the side of the circulation motor should be positioned within the base (Up or down? do they attached to a part or rest on the base for noise reduction. Can someone give me some guidance on this before I attempt to reassemble.
Thanks, Garry
