Register | FAQ's | New Posts | Today's Posts | Extras |
» Kenmore Ultra Wash. No lights dead |
![]() Model Number: 665.16732 Brand: Kenmore Age: More than 10 years
![]() My Kenmore died. No lights on display, will not start. here is what I've done. 1. checked handle latch and switch. All works. Power in and out of switch. 2. Have power to the thermal cutout and out to the control board. 3. Removed all connectors and ribbon wire. 4. inspected PC board. no signs of burning or bad solder joints. Re-installed control board. still no power. Is there anything else other than the control board that could cause this. I can get a control board for around $65 But would appreciate a second opinion about my diagnosis before spending hard to come by $$ that I can't get back Thanks in advance David Related Models Last edited by Davesnothere : 07-05-2013 at 07:53 AM. Reason: Wrong model # 665.15739 |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() Okay, I found the problem i think. on the flexible ribbon wire there are 8 pathways that that have been disrupted. Probably due to a lightning strike as it worked fine before a thunderstorm the other day. The ribbon and user interface seem to be bonded. Do I have to replace the entire panel? Do you have one? PN on it is 3383469 for black
![]() Your model number seems to be short several digits at the end.
Kenmore numbers are usually 3 numbers, a period and then an additional 8 numbers. Not sure what you mean by "8 pathways that that have been disrupted". If you mean they burned up then odds are that the control board is also toast. It is probably not worth fixing if you have to replace both the control panel and the control board.
__________________
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Kenmore Ultra Wash lights stuck on - no reset available | pkdm53a | Dishwasher Repair | 0 | 06-03-2013 07:23 AM |
Kenmore Ultra Wash - No lights | jim.nabber.va@gmail.com | Dishwasher Repair | 3 | 08-18-2011 03:46 PM |
kenmore ultra wash 665.16354300 Very noisy during wash cycle | hogues | Dishwasher Repair | 1 | 03-07-2010 02:47 PM |
Kenmore ultra wash Non responsive with ALL Lights steady ON?? | Silverblue | Dishwasher Repair | 0 | 08-19-2009 07:14 AM |
Kenmore Ultra Wash - Completely stopped working, no lights | gopogotom | Dishwasher Repair | 0 | 12-13-2008 08:41 AM |
