Dishes not cleaning well after any or several cycles. Detergent door opens, but detergent is not washed out, only dampened at the end of the cycle. I suspect the water pressure is low, either because an inlet water screen/filter is dirty or the pump is weak. Is there an inlet filter to clean, and if so how?
