Have a Bosch with push button controls on front door and when I select the Economy setting it will run, and run, and run and never seems to complete the cycle. It ran 8 hours the other night.
I removed the front panel and it appears that the wiring harness is ok and if I manually move the timer it will get to the dry cycle, but the on/off switch will never pop out and shut off. I noticed that the plastic plug in the time that drives the front door display appears to be stuck and not turning, leaving me to believe the time could not turn. I removed the plus and ran the machine and it still never completed the cycle after 2 hours.
I have replaced the pump 3 months ago and it is working fine. I repaired the wiring harness 2x where the wires broke with the door opening all the time and that seems at this time. It drains, it heats and all looks good inside the front door, no shorts, loose wires, etc.
Any suggestions?
