Discuss
Kitchen aid wash cycle for 2 hours
 in
Dishwasher Repair
I installed my own dishwasher. It is a KUD1021. I have installed enough dishwashers to know that everything was installed
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Kitchen aid wash cycle for 2 hours
  #1 (permalink)
Old 02-07-2008, 11:05 PM
Junior Member
trigger is on a distinguished road
Default Kitchen aid wash cycle for 2 hours
Brand: -brand-   Age: Less than 1 year
I have installed enough dishwashers to know that everything was installed correctly. After I installed and check leaks I ran it through a test cycle. Decided to do the heavy duty cycle. After an hour of watching the news I came back to check on it and it was still in the wash cycle. So I stayed there for about 30 minutes and it would wash, wash, wash, etc. never advancing to the next cycle. After two total hours it was obvious something was wrong so I canceled the cycled and it drained properly. I am just not sure what is causing it not to advance past the wash cycle. I make appliance deliveries/installs but I and not a repair man. My guess is that its the control panel or perhaps its a heating issue.
This dishwasher is brand new though it is probably 6-12 months old. I got it basically for free because we could never sell it.
Any ideas would be helpful.
-trigger
Ads By Google
  #2 (permalink)
Old 02-08-2008, 05:13 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The first thing - if it's less then a year old by the manufacturing date, coded in the serial number- it is still under the manufacturer warranty and you do not need any prove of purchase. Just tell them that it came with the house.
The problem could be caused by the incoming water temperature if it's much less then 120°F due to water heats up to proper temperature by the dishwasher .
Check the "Use and Care" book for the estimated time for the heavy duty cycle. It could be more then 120 minutes.
If you would like more accurate advise I need the complete model number of the dishwasher.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 02-09-2008, 02:12 PM
Junior Member
Default
Yes it is the water temp coming in.
I decided to run the water in the sink prior to starting the dishwasher until it was warm. Then started the dishwasher on normal and everything works fine.
I haven't tried the heavy duty again since I realized it was the water temperature going in. The heavy duty has to reach 151 degrees. But we usually rinse the dishes prior to putting in the dishwasher so normal wash is fine since we really use it to sanitize.
I am going to run a heavy duty cycle now that I know the dishwasher works and I'll post the results in case someone else experiences a similar problem. Only other problem is that the dishwasher doesn't have a manual so I am not sure on the Heavy Duty Cycle run-time.
The model number is a KUD1021RBL3.
I tried to google this model number it its hard to find much about it.
-trigger
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Wash machine starts on different segment of wash cycle than what we set it to rbarnes18 Washer Repair 1 01-01-2010 07:03 AM
When wash is complete the machine stay on agitate and won't allow a new wash cycle Trofytrout Washer Repair 1 07-07-2009 01:34 PM
Whirlpool dishwasher taking 12+ hours to complete a cycle - please help! becstar Dishwasher Repair 4 03-04-2009 11:26 AM
Long Wash Cycle (5+ hours) smackay13 Dishwasher Repair 3 12-18-2008 09:57 PM
Can not select wash cycle - stuck on scrub wash luke Dishwasher Repair 0 08-20-2007 08:38 AM
