Discuss
Maytag mdb7609aws2 dishwasher won't start
 in
Dishwasher Repair
Hello. My dishwasher is 2 years, 7 months old and it won't start. My situation is almost (if not) identical
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Maytag mdb7609aws2 dishwasher won't start
  #1 (permalink)
Old 06-09-2013, 12:49 PM
Junior Member
karlglen101 is on a distinguished road
Default Maytag mdb7609aws2 dishwasher won't start
Model Number: mdb7609aws2   Brand: Maytag   Age: 1 - 5 years
Hello. My dishwasher is 2 years, 7 months old and it won't start. My situation is almost (if not) identical to this thread:
Maytag dishwasher MDB7609AWS2 won't start
From reading here, and a few DIY type sites, I've done the following:
-hit normal - heated dry - normal (5 times) and it entered a maintenance cycle. All of my lights came on when I did this. The water started to fill, but nothing really happened otherwise. Eventually, the water was starting to drip out, so I unplugged it as it's not hard wired.
-I disconnected the control panel from the control box. I then closed the door, and plugged the dishwasher back in. I could hear what sounds like a solenoid click twice in the control box, but the drain motor wouldn't kick in. While I was disconnecting parts, and examining things, I tripped the door latch and it snapped on my finger with some force. It does not appear to be broken, but it also doesn't seem to latch correctly now when I close the door. I then tested the door latch switch for continuity, and it tested fine. I then plugged the washer back in with the panel disconnected, closed the door switch manually, and the drain motor kicked in just fine and drained the water out. I believe I am having one or two problems, and wanted to get your thoughts.
1) bad control panel. I can also see what appears to be some rust spots inside the panel on the ribbon. I can't figure out how to separate the control panel. Is it not serviceable? I want to get a better look as it might just be the control ribbon.
2) likely in addition to #1, the door latch is broken. I reconnected the panel to the control box, closed the switch manually, and still could not get the start button to do anything. I know that really doesn't prove the switch being broken, but the test to get the drain motor to kick on points to it.
All help is appreciated.
Related Models
Maytag MDB7609AWS2 UNDERCOUNTER DISHWASHER
Maytag MDB7609AWW0 UNDERCOUNTER DISHWASHER
Maytag MDB7609AWW1 UNDERCOUNTER DISHWASHER
Maytag MDB7609AWW2 UNDERCOUNTER DISHWASHER
Maytag MDB7650AWB DISHWASHER- UNDERCOUNTER
Maytag MDB7650AWQ DISHWASHER- UNDERCOUNTER
Maytag MDB7650AWS DISHWASHER- UNDERCOUNTER
Maytag MDB7650AWW DISHWASHER- UNDERCOUNTER
Maytag MDB7709AWB0 UNDERCOUNTER DISHWASHER
Maytag MDB7709AWB1 UNDERCOUNTER DISHWASHER
Maytag MDB7709AWB2 UNDERCOUNTER DISHWASHER
Maytag MDB7709AWQ0 UNDERCOUNTER DISHWASHER
Maytag MDB7709AWQ1 UNDERCOUNTER DISHWASHER
Maytag MDB7709AWQ2 UNDERCOUNTER DISHWASHER
Maytag MDB7709AWS0 UNDERCOUNTER DISHWASHER
Maytag MDB7709AWS1 UNDERCOUNTER DISHWASHER
Maytag MDB7709AWS2 UNDERCOUNTER DISHWASHER
Maytag MDB7709AWW0 UNDERCOUNTER DISHWASHER
Maytag MDB7709AWW1 UNDERCOUNTER DISHWASHER
Maytag MDB7709AWW2 UNDERCOUNTER DISHWASHER
Maytag MDB7750AWB DISHWASHER- UNDERCOUNTER
Maytag MDB7750AWQ DISHWASHER- UNDERCOUNTER
Maytag MDB7750AWS DISHWASHER- UNDERCOUNTER
Maytag MDB7750AWW DISHWASHER- UNDERCOUNTER
Maytag MDB7751AWB DISHWASHER- UNDERCOUNTER
Maytag MDB7751AWQ DISHWASHER- UNDERCOUNTER
Maytag MDB7751AWS DISHWASHER- UNDERCOUNTER
Maytag MDB7751AWW DISHWASHER- UNDERCOUNTER
Maytag MDB7755AWB DISHWASHER- UNDERCOUNTER
Maytag MDB7755AWQ DISHWASHER- UNDERCOUNTER
Maytag MDB7755AWS DISHWASHER- UNDERCOUNTER
Maytag MDB7755AWW DISHWASHER- UNDERCOUNTER
Maytag MDB7759AWB0 UNDERCOUNTER DISHWASHER
Maytag MDB7759AWS0 UNDERCOUNTER DISHWASHER
Maytag MDB7759AWW0 UNDERCOUNTER DISHWASHER
Maytag MDB7809AWB0 UNDERCOUNTER DISHWASHER
Maytag MDB7809AWB1 UNDERCOUNTER DISHWASHER
Maytag MDB7809AWB2 UNDERCOUNTER DISHWASHER
Maytag MDB7809AWM0 UNDERCOUNTER DISHWASHER
Maytag MDB7809AWM1 UNDERCOUNTER DISHWASHER
Maytag MDB7809AWM2 UNDERCOUNTER DISHWASHER
Maytag MDB7809AWQ0 UNDERCOUNTER DISHWASHER
Maytag MDB7809AWQ1 UNDERCOUNTER DISHWASHER
Maytag MDB7809AWQ2 UNDERCOUNTER DISHWASHER
Maytag MDB7809AWW0 UNDERCOUNTER DISHWASHER
Maytag MDB7809AWW1 UNDERCOUNTER DISHWASHER
Maytag MDB7809AWW2 UNDERCOUNTER DISHWASHER
Maytag MDB7851AWB0 UNDERCOUNTER DISHWASHER
Maytag MDB7851AWB1 UNDERCOUNTER DISHWASHER
Maytag MDB7851AWB10 UNDERCOUNTER DISHWASHER
Maytag MDB7851AWB41 UNDERCOUNTER DISHWASHER
Maytag MDB7851AWB44 UNDERCOUNTER DISHWASHER
Maytag MDB7851AWQ0 UNDERCOUNTER DISHWASHER
Maytag MDB7851AWQ1 UNDERCOUNTER DISHWASHER
Maytag MDB7851AWQ10 UNDERCOUNTER DISHWASHER
Maytag MDB7851AWQ41 UNDERCOUNTER DISHWASHER
Maytag MDB7851AWQ44 UNDERCOUNTER DISHWASHER
Maytag MDB7851AWS0 UNDERCOUNTER DISHWASHER
Maytag MDB7851AWS1 UNDERCOUNTER DISHWASHER
Maytag MDB7851AWS10 UNDERCOUNTER DISHWASHER
Maytag MDB7851AWS41 UNDERCOUNTER DISHWASHER
Maytag MDB7851AWS44 UNDERCOUNTER DISHWASHER
Maytag MDB7851AWW0 UNDERCOUNTER DISHWASHER
Maytag MDB7851AWW1 UNDERCOUNTER DISHWASHER
Maytag MDB7851AWW10 UNDERCOUNTER DISHWASHER
Maytag MDB7851AWW41 UNDERCOUNTER DISHWASHER
Maytag MDB7851AWW44 UNDERCOUNTER DISHWASHER
Maytag MDB8000AWA DISHWASHER- UNDERCOUNTER
Maytag MDB8000AWB DISHWASHER- UNDERCOUNTER
Maytag MDB8000AWW DISHWASHER- UNDERCOUNTER
Maytag MDB8600AWB DISHWASHER- UNDERCOUNTER
Maytag MDB8600AWQ DISHWASHER- UNDERCOUNTER
Maytag MDB8600AWS DISHWASHER- UNDERCOUNTER
Maytag MDB8600AWW DISHWASHER- UNDERCOUNTER
Maytag MDB8601AWB10 UNDERCOUNTER DISHWASHER
Maytag MDB8601AWB41 UNDERCOUNTER DISHWASHER
Maytag MDB8601AWQ41 UNDERCOUNTER DISHWASHER
Maytag MDB8601AWS10 UNDERCOUNTER DISHWASHER
Maytag MDB8601AWS41 UNDERCOUNTER DISHWASHER
Maytag MDB8601AWW10 UNDERCOUNTER DISHWASHER
Maytag MDB8601AWW41 UNDERCOUNTER DISHWASHER
Maytag MDB8750AWB DISHWASHER- UNDERCOUNTER
Maytag MDB8750AWQ DISHWASHER- UNDERCOUNTER
Maytag MDB8750AWS DISHWASHER- UNDERCOUNTER
Maytag MDB8750AWW DISHWASHER- UNDERCOUNTER
Maytag MDB8751AWB DISHWASHER- UNDERCOUNTER
Maytag MDB8751AWQ DISHWASHER- UNDERCOUNTER
Maytag MDB8751AWS DISHWASHER- UNDERCOUNTER
Maytag MDB8751AWW DISHWASHER- UNDERCOUNTER
Maytag MDB8751BWB DISHWASHER- UNDERCOUNTER
Maytag MDB8751BWQ DISHWASHER- UNDERCOUNTER
Maytag MDB8751BWS DISHWASHER- UNDERCOUNTER
Maytag MDB8751BWW DISHWASHER- UNDERCOUNTER
Maytag MDB8851AWB0 UNDERCOUNTER DISHWASHER
Maytag MDB8851AWB1 UNDERCOUNTER DISHWASHER
Maytag MDB8851AWB10 UNDERCOUNTER DISHWASHER
Maytag MDB8851AWB41 UNDERCOUNTER DISHWASHER
Maytag MDB8851AWB44 UNDERCOUNTER DISHWASHER
Maytag MDB8851AWB45 UNDERCOUNTER DISHWASHER
Maytag MDB8851AWS0 UNDERCOUNTER DISHWASHER
Maytag MDB8851AWS1 UNDERCOUNTER DISHWASHER
Maytag MDB8851AWS10 UNDERCOUNTER DISHWASHER
Maytag MDB8851AWS41 UNDERCOUNTER DISHWASHER
Maytag MDB8851AWS44 UNDERCOUNTER DISHWASHER
Maytag MDB8851AWS45 UNDERCOUNTER DISHWASHER
Maytag MDB8851AWW0 UNDERCOUNTER DISHWASHER
Maytag MDB8851AWW1 UNDERCOUNTER DISHWASHER
Maytag MDB8851AWW10 UNDERCOUNTER DISHWASHER
Maytag MDB8851AWW41 UNDERCOUNTER DISHWASHER
Maytag MDB8851AWW44 UNDERCOUNTER DISHWASHER
Maytag MDB8851AWW45 UNDERCOUNTER DISHWASHER
Maytag MDB8859AWB0 UNDERCOUNTER DISHWASHER
Maytag MDB8859AWB1 UNDERCOUNTER DISHWASHER
Maytag MDB8859AWB2 UNDERCOUNTER DISHWASHER
Maytag MDB8859AWB3 UNDERCOUNTER DISHWASHER
Maytag MDB8859AWS0 UNDERCOUNTER DISHWASHER
Maytag MDB8859AWS1 UNDERCOUNTER DISHWASHER
Maytag MDB8859AWS2 UNDERCOUNTER DISHWASHER
Maytag MDB8859AWS3 UNDERCOUNTER DISHWASHER
Maytag MDB8859AWW0 UNDERCOUNTER DISHWASHER
  #2 (permalink)
Old 09-12-2016, 09:34 PM
Junior Member
WeAreNotAlone is on a distinguished road
Default
Did you ever get the Maytag MDB7609AWS2 dishwasher back up and running?
What was the problem (in as much detail as you can remember.)
TIA
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag dishwasher MDB7609AWS2 won't start minvac Dishwasher Repair 8 09-12-2016 10:28 PM
Maytag Dishwasher won't start bendermichael Dishwasher Repair 0 07-31-2012 11:30 AM
Maytag dishwasher won't start gunner_1911 Dishwasher Repair 1 09-28-2011 08:30 AM
Maytag dishwasher will not start lauranne Dishwasher Repair 3 03-28-2011 12:00 PM
Maytag dishwasher won't start griz369 Dishwasher Repair 1 02-16-2011 08:33 AM
