29-1
#1 Posted : Sunday, June 9, 2013 10:48:46 AM(UTC)
29-1
Hi, I have a Maytag Jet Clean Quiet + Dishwasher that with the exception of a control panel replacement a couple of years ago has been great. I recently began having problems with the door latch and ordered a new latch and door latch handle not knowing for certain which part was bad. Well, after getting things apart I discovered it was the handle which had cracked in two and the two ears on the door front shell which receives the screws that hold both the door and door latch switch together were broken off. I had to make shift the screw inserts with super glue to hold things together but this isn't going to last long. What it looks like I need is the complete front door shell with the two handle studs that are one molded unit. Any idea how to get just the shell? I don't want to scrap a perfectly good dishwasher for a failed plastic screw stud.
Chuck
