Discuss
Maytag dishwasher not drying
 in
Dishwasher Repair
Our dryer hasn't been drying for about a week now. I ran the diagnostic on the heating element and
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Maytag dishwasher not drying
  #1 (permalink)
Old 02-07-2008, 06:48 PM
kaustin36 kaustin36 is offline
Junior Member
kaustin36 is on a distinguished road
Default Maytag dishwasher not drying
Model Number: MDB9100   Brand: Maytag   Age: 5 - 10 years
Our dryer hasn't been drying for about a week now. I ran the diagnostic on the heating element and it doesn't turn on at all. I'm not convinced it's the heating element, so I then broke down the dishwasher to view the control board. On the back side of it, I noticed a small burn (soot-like) area at one of the solder points, maybe 1/2" in diameter. I'm guessing this is not good; I'm trying to determine if the board simply shorted out or if something else caused it.
Also, I just read this thread: Heater Element Disconnected
The bottom of it does an excellent job of describing they symptons. Not drying, much longer cycle time, etc. I did have the recall work done on this about 4 months ago, but I'm sure it's been working fine up to the last week or so. Perhaps coincidental.
Thoughts? Thank you.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-07-2008, 07:31 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would do is check for continuity the heating element and the hi limit thermostat (#16 on the tub break down diagram).
If any of them is open, it has to be replaced.
If there is nothing wrong then the problem is a bad control board.
- The part number for the hi limit thermostat is AP2644587
In order to provide the right part number for the control board and the heating element I need the serial number of the dishwasher.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 02-08-2008, 08:16 AM
Junior Member
Default re: Maytag dishwasher not drying
Forgive my ignorance here....I do have a (analog) multimeter, but it doesn't have a RX1 setting...it does have a OhmsX10 setting which is the lowest it goes. I set it to that and checked the heating element and hi-limit thermostat; for both of them, the needle swings from the left side (infinity) of the scale to the right and lands around 0. Is this enough to tell me that the components are good or should I find and use a multi-meter with better granularity? So far, I'm thinking these parts are fine and that it looks like I need a new control board. Can you confirm? Thanks! s/n: 23872007YU Model: MDB9100AWW
  #4 (permalink)
Old 02-08-2008, 01:05 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Looks like the problem is the control board.
- The part number for the control board is AP3158622
Good luck.
__________________
  #5 (permalink)
Old 02-29-2008, 05:35 PM
Junior Member
Default
Gene, Thanks for your excellent opinion! In fact, it was the control board. After a fast shipment and about 20 minutes, I had it running once again. Thanks!!
  #6 (permalink)
Old 02-29-2008, 10:21 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm glad you were able to fix it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher not drying princess Dishwasher Repair 0 01-26-2008 12:47 PM
Maytag dryer drying slowly stodtmeister Dryer Repair 3 12-12-2007 06:12 PM
Bosch SMU4056 Dishwasher not drying tmsimonson Dishwasher Repair 4 11-29-2007 04:08 PM
maytag dishwasher rschem Dishwasher Repair 3 11-09-2007 01:56 PM
Maytag dryer not heating up on all cycles and not properly drying clothes. radioman464 Dryer Repair 1 10-18-2007 04:48 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
