Hello, At the end of the wash cycle I notice the drain pump runs for a few minutes intermittently until I hit the off button. If I remove the strainer from the sump when it is running, I see water gushing out from around the seal between the stainless steel tub and the plastic sump. What do I need to do to fix the issue? The model is she44co6uc/47.
