dhan
#1 Posted : Thursday, May 16, 2013 12:18:29 PM(UTC)
dhan
Had this problem before and replaced the valve and nut.It worked then so I replaced it this time,but still won't drain complety.
Joe / APP Team
#2 Posted : Friday, May 17, 2013 1:53:54 PM(UTC)
Joe / APP Team
Dhan, If you haven't yet, you'll need to remove the sump cover and filter in the center rear portion of the tub, and check to see that the filter and cover aren't clogged and the sump is clear of any debris. Also check the drain hose, disposal and air gap(if applicable) for clogs. Disconnect the drain hose from the fitting under the sink, fill and drain the dishwasher into a large bucket, this will clear any debris in the drain hose.
