Discuss
Is it the control panel or control board
 in
Dishwasher Repair
MODEL NUMBER: MDB7609AWS The only lights that do not work on the panel are start, cancel, and high temp. The
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Is it the control panel or control board
  #1 (permalink)
Old 05-13-2013, 07:11 PM
Member
bluefitness is on a distinguished road
Default Is it the control panel or control board
Brand: Maytag   Age: 1 - 5 years
The only lights that do not work on the panel are start, cancel, and high temp. The start and cancel buttons are not responsive. I checked power going up to the board and it is getting power. I'm thinking it is the control panel. I did some research and others seem to have the same problem, and it turned out to be the control panel. Is there a way to know for sure? Can you provide a link to a tech sheet and the part?
  #2 (permalink)
Old 05-13-2013, 09:09 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
Most likely the problem is a bad control panel but there is a small chance for the control board to be bad as well.
You can verify it by doing the following test:
1. Unplug dishwasher or disconnect power.
2. Open the dishwasher door.
3. Open console and disconnect the keypad ribbon connection from the control (at P1). Make sure all other connections are made.
4. Put console back together. Do not close the dishwasher door.
5. Plug in dishwasher or reconnect power.
6. Wait 5 sec.
7. Close dishwasher door.
8. Monitor the control’s response:
If the control is OK (no longer sees shorts with the keypad unplugged), it will respond by turning on the Drain Motor for 2 minutes. Replace the keypad (control panel) if the control responds OK.
If the control is not OK (still sees shorts with the keypad unplugged), then the drain motor will NOT turn on. If the drain motor does not start within 10 sec, replace the control board.
If you need the correct part numbers, post the end of the model number and the color of the control panel.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 05-13-2013, 09:42 PM
Member
Default
The drain motor came on as you stated. Can you give me a link to the correct control panel?
MDB7609AWS2
Type No: 577-0
It is a stainless model with black panel.
  #4 (permalink)
Old 05-14-2013, 04:44 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome.
- The black control panel Part number: W10254846
Here are the breakdown diagrams and Parts for Maytag MDB7609AWS2 Dishwasher - AppliancePartsPros.com
__________________
  #5 (permalink)
Old 05-15-2013, 09:40 AM
Member
Default
Thanks. I just placed an order with you.
  #6 (permalink)
Old 05-15-2013, 06:56 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
__________________
  #7 (permalink)
Old 09-12-2016, 10:40 PM
Junior Member
WeAreNotAlone is on a distinguished road
Default
Q: Did the control panel fix the Maytag MDB7609AWS dishwasher?
Is it still working 3yrs later?
PS: Did you see any sign of water damage when replacing the control panel?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag control board connector type for control panel cable? damoappc Dishwasher Repair 4 12-03-2012 04:29 PM
Jenn-Air Control Board or Control Panel which to replace? mavantix Dishwasher Repair 7 07-31-2012 07:54 PM
No Display Troubleshooting: Control Panel Assy or Electronic Clock Control Board hddman Oven Repair (including Ranges and Cooktops) 0 04-26-2010 01:09 PM
