Discuss
Maytag Dishwasher Humming (starts washing then hums)
 in
Dishwasher Repair
Hi, These are the symptoms that I have been experiencing: The dishwasher fills with water normally, then the wash cycle
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Maytag Dishwasher Humming (starts washing then hums)
  #1 (permalink)
Old 05-07-2013, 03:23 PM
Junior Member
Forcedbird is on a distinguished road
Default Maytag Dishwasher Humming (starts washing then hums)
Model Number: MDC4650AWW1   Brand: Maytag   Age: 1 - 5 years
The dishwasher fills with water normally, then the wash cycle starts. It sprays water around for about 2-3 seconds then it starts to hum from the motor area and the spraying stops.
Sometimes after a few minutes(of humming) the dishwasher starts spraying water again (for 2-3 seconds).....but it goes back to that humming noise and stops spraying again.
During the humming I have opened the door to take a look what's going on inside. I notice that during the humming noise that water is coming out of the lower washer arm but it is very weak.
I have first replaced the water inlet valve valve:
06-Fill and Overfill Parts parts for Maytag MDC4650AWW1 - AppliancePartsPros.com (#2 in diagram).
After replacing this part the dishwasher actually worked for 1 wash. I felt like my dishes came out cleaner than ever!!!!.
I went to wash another load about 6 days later and then that's when the problem stated above returned. But I noticed something else that happened, it started to drain after about 2 minutes into the wash cycle (during the humming sound). It did this about 3 times and then it never did it again.
I decided to check the continuity of the (recently replaced) water inlet valve, I set my digital multi meter (DMM) to 200 ohms (which in this model on the 200 ohm setting only, has a "beeping" sound if there is continuity. To my surprise the water inlet valve did not have continuity (and no beeping was heard). I called the appliancepartspros.com and they sent me a replacement part right away.
When I got the replacement water inlet valve, I decided to check the continuity of the valve before replacing the part. Well to my surprise again! no continuity! (FYI check my DMM to see if it is working properly, and it is). Called into to appliancepartspros.com again made sure that this water inlet valve is supposed to have continuity, they said yes and replaced the part again.
OK, now when I received the part I did the same as before and checked for continuity...........and again.......no continuity!!!! Alright so now I thought to myself, am I doing something wrong here. Well what I did next was I set my DDM on the 2k ohms setting....well I got a reading of 1.103 (does this mean it has continuity?). I did this again for the 20K, 200K, and 2M and I got a reading for all of those settings. Now I am not an electrical expert for the record.....but I am thinking that this valve maybe working properly.
Called into appliancepartspros.com and asked for their advice. They said that it could be the motor. I purchased one, installed it and it's still not working (same symptoms....humming).
Called appliancepartspros.com again they said with my model number that there was a technical service bulletin about the wiring in the door that was shorting out with the adhesive on the insulation. Checked that, pulled the insulation and it appears that all of the insulation on the wiring is intact.
I had a hunch that it might be the control board. Ordered that, replaced it today and still not working with the same symptoms. At this point I am starting to get frustrated. I kind of like a challenge in problem solving but this is getting ridiculous! I have a lot of time and money tied up into this thing right now. I am starting to think that I should have called a repair person or trashed this dishwasher and purchased a new one.
If anyone can please help it would be greatly appreciated.
Thank you in advance!!!!
Related Models
Maytag MDC4650AWW1 PORTABLE DISHWASHER
Maytag MDC4650AWW2 PORTABLE DISHWASHER
Maytag MDC4650AWW3 PORTABLE DISHWASHER
Maytag MDC4809AWB0 PORTABLE DISHWASHER
Maytag MDC4809AWW0 PORTABLE DISHWASHER
Maytag MDC5100AWB DISHWASHER- CONVERTIBLE
Maytag MDC5100AWW DISHWASHER- CONVERTIBLE
Magic Chef MDCP1085- DRYER- ELE
Magic Chef MDCP1085-A DRYER- ELE
Frigidaire MDD25TF1 Frg(v1) / Dehumidifier
Frigidaire MDD25TG1 Gib(v1) / Dehumidifier
Frigidaire MDD25WF1 Frg(v1)
Frigidaire MDD25WG1 Gib(v1) / Dehumidifier
Frigidaire MDD25WW1 Wwh(v1) / Dehumidifier
Frigidaire MDD30FW1 Wwh(v0) / Dehumidifier
Frigidaire MDD30FW2 Wwh(v0) / Dehumidifier
Frigidaire MDD30TF1 Frg(v2) / Dehumidifier
Frigidaire MDD30TG1 Gib(v2) / Dehumidifier
Frigidaire MDD30TG2 Gib(v3) / Dehumidifier
Frigidaire MDD30WF1 Frg(v2)
Frigidaire MDD30WG1 Gib(v2) / Dehumidifier
Frigidaire MDD30WG2 Gib(v0) / Dehumidifier
Frigidaire MDD30WW1 Wwh(v1) / Dehumidifier
Frigidaire MDD40TF1 Frg(v1) / Dehumidifier
Frigidaire MDD40TG1 Gib(v1) / Dehumidifier
Frigidaire MDD40TG3 Gib(v0) / Dehumidifier
Frigidaire MDD40WF1 Frg(v3)
Frigidaire MDD40WF2 Frg(v4)
Frigidaire MDD40WG1 Gib(v3) / Dehumidifier
Frigidaire MDD40WG2 Gib(v4) / Dehumidifier
Frigidaire MDD40WW2 Wwh(v2) / Dehumidifier
Frigidaire MDD40WW4 Wwh(v3) / Dehumidifier
Frigidaire MDD50TF1 Frg(v2) / Dehumidifier
Frigidaire MDD50TF2 Frg(v3) / Dehumidifier
Frigidaire MDD50TG1 Gib(v2) / Dehumidifier
Frigidaire MDD50TG2 Gib(v3) / Dehumidifier
Frigidaire MDD50WF1 Frg(v5)
Frigidaire MDD50WG1 Gib(v5) / Dehumidifier
Frigidaire MDD50WG2 Gib(v0) / Dehumidifier
Frigidaire MDD50WW1 Wwh(v2) / Dehumidifier
Frigidaire MDD50WW2 Wwh(v0) / Dehumidifier
Maytag MDD8000AWB0 DRAWER DISHWASHER
Maytag MDD8000AWB2 DRAWER DISHWASHER
Maytag MDD8000AWS0 DRAWER DISHWASHER
Maytag MDD8000AWS2 DRAWER DISHWASHER
Maytag MDD8000AWS3 DRAWER DISHWASHER
Frigidaire MDDQ40FF1 Frg(v0) / Dehumidifier
Frigidaire MDDQ40FF3 Frg(v0) / Dehumidifier
Frigidaire MDDQ40FG1 Gib(v0) / Dehumidifier
Frigidaire MDDQ40FW1 Wwh(v1) / Dehumidifier
Frigidaire MDDQ40FW3 Wwh(v0) / Dehumidifier
Frigidaire MDDQ50FF1 Frg(v0) / Dehumidifier
Frigidaire MDDQ50FF2 Frg(v0) / Dehumidifier
Frigidaire MDDQ50FF3 Frg(v0) / Dehumidifier
Frigidaire MDDQ50FG1 Gib(v0) / Dehumidifier
Frigidaire MDDQ50FG2 Gib(v0) / Dehumidifier
Frigidaire MDDQ50FG3 Gib(v0) / Dehumidifier
Frigidaire MDDQ50FW1 Wwh(v2) / Dehumidifier
Frigidaire MDDQ50FW2 Wwh(v0) / Dehumidifier
Frigidaire MDDQ50FW6 Wwh(v0) / Dehumidifier
Maytag MDE10CSACL MAYTAG LAUNDRY (DRYER ELE)
Maytag MDE10CSACW MAYTAG LAUNDRY (DRYER ELE)
Maytag MDE10CSADL MAYTAG LAUNDRY (DRYER ELE)
Maytag MDE10CSADW MAYTAG LAUNDRY (DRYER ELE)
Maytag MDE10CSAGL MAYTAG LAUNDRY (DRYER ELE)
Maytag MDE10CSAGW MAYTAG LAUNDRY (DRYER ELE)
Maytag MDE10CSAKL MAYTAG COMMERCIAL LAUNDRY (DRYER ELE)
Maytag MDE10DAACL MAYTAG LAUNDRY (DRYER ELE)
Maytag MDE10DAACW MAYTAG LAUNDRY (DRYER ELE)
Maytag MDE10DAADL MAYTAG LAUNDRY (DRYER ELE)
Maytag MDE10DAADW MAYTAG LAUNDRY (DRYER ELE)
Maytag MDE10DAAEL MAYTAG LAUNDRY (DRYER ELE)
Maytag MDE10DAAEW MAYTAG LAUNDRY (DRYER ELE)
Maytag MDE10MNACW MAYTAG COMMERCIAL LAUNDRY (DRYER ELE)
Maytag MDE10MNADW MAYTAG COMMERCIAL LAUNDRY (DRYER ELE)
Maytag MDE10MNAEW MAYTAG COMMERCIAL LAUNDRY (DRYER ELE)
Maytag MDE10MNAGW MAYTAG COMMERCIAL LAUNDRY (DRYER ELE)
Maytag MDE10PDACL MAYTAG LAUNDRY (DRYER ELE)
Maytag MDE10PDACW MAYTAG LAUNDRY (DRYER ELE)
Maytag MDE10PDADL MAYTAG LAUNDRY (DRYER ELE)
Maytag MDE10PDADW MAYTAG LAUNDRY (DRYER ELE)
Maytag MDE10PDAEL MAYTAG LAUNDRY (DRYER ELE)
Maytag MDE10PDAEW MAYTAG LAUNDRY (DRYER ELE)
Maytag MDE10PDEGL MANUAL, PARTS (EXPORT) (DRYER ELE)
Maytag MDE10PDEGW MANUAL, PARTS (EXPORT) (DRYER ELE)
Maytag MDE10PRACW MANUAL, PARTS (DRYER ELE)
Maytag MDE10PSADW MANUAL, PARTS (DRYER ELE)
Maytag MDE10PSAGL MAYTAG LAUNDRY (DRYER ELE)
Maytag MDE10PSAGW MAYTAG LAUNDRY (DRYER ELE)
Frigidaire MDE116RBW0 Frg(v1) / 27 " Electric Dryer
Frigidaire MDE116RBW1 Wwh(v1) / Electric Dryer
Frigidaire MDE116RBW2 Frg(v0) / Electric Dryer
Frigidaire MDE116REW0 Frg(v1) / Electric Dryer
Frigidaire MDE116REW1 Frg(v0) / Dryer
Maytag MDE11CSACL MANUAL, PARTS (DRYER ELE)
Maytag MDE11CSACW MANUAL, PARTS (DRYER ELE)
Maytag MDE11CSADL MANUAL, PARTS (DRYER ELE)
Maytag MDE11CSADW MANUAL, PARTS (DRYER ELE)
Maytag MDE11CSAGL MANUAL, PARTS (DRYER ELE)
Maytag MDE11CSAGW MANUAL, PARTS (DRYER ELE)
Maytag MDE11MNACW MAYTAG COMMERCIAL LAUNDRY (DRYER ELE)
Maytag MDE11MNADW MAYTAG COMMERCIAL LAUNDRY (DRYER ELE)
Maytag MDE11MNAGW MANUAL, PARTS (DRYER ELE)
Maytag MDE11PDACL MANUAL, PARTS (DRYER ELE)
Maytag MDE11PDACW MANUAL, PARTS (DRYER ELE)
Maytag MDE11PDADL MANUAL, PARTS (DRYER ELE)
Maytag MDE11PDADW MANUAL, PARTS (DRYER ELE)
Maytag MDE11PDAEL MAYTAG COMMERCIAL LAUNDRY (DRYER ELE)
Maytag MDE11PDAEW MAYTAG COMMERCIAL LAUNDRY (DRYER ELE)
Maytag MDE11PDAGL MANUAL, PARTS (EXPORT) (DRYER ELE)
Maytag MDE11PDAGW MANUAL, PARTS (EXPORT) (DRYER ELE)
Maytag MDE12CSACL MANUAL, PARTS (DRYER ELE)
Maytag MDE12CSACW MANUAL, PARTS (DRYER ELE)
Maytag MDE12CSADL MANUAL, PARTS (DRYER ELE)
Maytag MDE12CSADW MANUAL, PARTS (DRYER ELE)
Maytag MDE12CSAGW MANUAL, PARTS (DRYER GAS)
Maytag MDE12MNACW MANUAL, PARTS (DRYER ELE)
Maytag MDE12MNADW MANUAL, PARTS (DRYER ELE)
Maytag MDE12MNAGW MANUAL, PARTS (DRYER ELE)
Maytag MDE12PDACL MANUAL, PARTS (DRYER ELE)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher makes humming sound but not filling with water & washing lgscubagirl Dishwasher Repair 2 11-04-2012 09:52 PM
Maytag dishwasher starts and stops CKuhlman Dishwasher Repair 0 10-10-2010 09:34 AM
Whirlpool Washer Starts Stops And Hums beverlyjean Washer Repair 1 06-02-2009 03:35 PM
KenMore Dishwasher-Humming-not washing rickneedshelp Dishwasher Repair 0 03-27-2009 06:02 PM
Dryer just hums, and OCCASIONALLY actually starts. ms_hellkitty Dryer Repair 1 12-30-2008 06:09 PM
