Discuss
Bosch Dishwasher Soap Not Dispensing Correctly
 in
Dishwasher Repair
My Bosch dishwasher began to have a problem dispensing the soap tablets. The tablets would turn into a gel goo
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch Dishwasher Soap Not Dispensing Correctly
  #1 (permalink)
Old 05-02-2013, 08:49 PM
MrD MrD is offline
Junior Member
MrD is on a distinguished road
Default Bosch Dishwasher Soap Not Dispensing Correctly
Model Number: SHE43RF6UC/64 and similar   Brand: Bosch   Age: 1 - 5 years
My Bosch dishwasher began to have a problem dispensing the soap tablets. The tablets would turn into a gel goo and would be stuck in the dispenser even though the dispenser lid was open.
After much research, I stumbled across a description of the function of the wax motor. Based on the description, I came to the conclusion that the motor/actuator system that operates the soap dispenser, ALSO activates the rinse. Like a clicker on a ink pin. The first push brings out the writing tip ... and the second retracts the tip.
Another way of saying it would be that the FIRST time the motor is activated, it dispenses soap. The SECOND time the motor is activated, it dispenses rinse.
What would happen if you were to interrupt and reset (power down) the dishwasher AFTER the soap was dispensed and BEFORE the rinse?
Well ... you would start the unit, it would dispense rinse, wash for a while and then, just before it finishes, dispense the soap (which has now melted inside the soap dispensing tray). This is my theory.
So, I started my dishwasher and run it for about 20 - 30 minutes ... interrupted the cycle ... then ran it again.
Yep ... the problem was fixed and it has been working flawlessly for about a month now.
BEFORE you spend a bunch of money on parts and the labor to replace the unit, try this "free" fix.
I hope it works for you like it did for me.
Related Models
Whirlpool SHF3801W0 Dishwasher
Whirlpool SHF3804W2 Dishwasher
Whirlpool SHF4500W0 Dishwasher
Whirlpool SHF5500W0 Dishwasher
Whirlpool SHF5501W0 Dishwasher
Whirlpool SHF5504W0 Dishwasher
Whirlpool SHF5584P1 Dishwasher
Whirlpool SHF5584P2 Dishwasher
Whirlpool SHF5801W0 Dishwasher
Whirlpool SHF5801W1 Dishwasher
Whirlpool SHF5884P1 Dishwasher
Whirlpool SHF5884P2 Dishwasher
Whirlpool SHF7800W0 Dishwasher
Whirlpool SHF7801W0 Dishwasher
Whirlpool SHF7804W1 Dishwasher
Whirlpool SHF7884P0 Dishwasher
Whirlpool SHF7884P1 Dishwasher
Whirlpool SHF7884P2 Dishwasher
Bosch SHI4302 UC/06 -FD8002
Bosch SHI4302 UC/11 -FD8003
Bosch SHI4302 UC/12
Bosch SHI4306 UC/06 -FD8002
Bosch SHI4306 UC/11 -FD8003
Bosch SHI4306 UC/12
Bosch SHI66A05 UC/14 (FD 8211-)
Bosch SHI6802 UC/06
Bosch SHI6802 UC/11
Bosch SHI6802 UC/12
Bosch SHI6805 UC/06
Bosch SHI6805 UC/11
Bosch SHI6805 UC/12
Bosch SHI6806 UC/06
Bosch SHI6806 UC/11
Bosch SHI6806 UC/12
Whirlpool SHU30011 DISHWASHER
Bosch SHU3002
Whirlpool SHU30041 DISHWASHER
Bosch SHU3006
Bosch SHU3012
Whirlpool SHU30140 DISHWASHER
Whirlpool SHU30141 DISHWASHER
Bosch SHU3016
Bosch SHU3032 UC/06 (FD 7908-8002)
Bosch SHU3032 UC/11 (FD 8002-8003)
Bosch SHU3032 UC/12 (FD 8003-)
Bosch SHU3035 UC/12 (FD 8006-)
Bosch SHU3036 UC/06 (FD 7908-8002)
Bosch SHU3036 UC/11 (FD 8002-8003)
Bosch SHU3036 UC/12 (FD 8003-)
Bosch SHU3132 UC/12 (FD 8105-)
Bosch SHU3135 UC/12 (FD 8105-)
Bosch SHU3136 UC/12 (FD 8105-)
Bosch SHU3302 UC/06 (FD 7902-8003)
Bosch SHU3302 UC/11 (FD 8003-8003)
Bosch SHU3302 UC/12 (FD 8003 -)
Bosch SHU3305 UC/06 (FD 7902-8003)
Bosch SHU3305 UC/11 (FD 8003-8003)
Bosch SHU3305 UC/12 (FD 8003 -)
Bosch SHU3306 UC/06 (FD 7902-8003)
Bosch SHU3306 UC/11 (FD 8003-8003)
Bosch SHU3306 UC/12 (FD 8003 -)
Bosch SHU3307 UC/12 (FD 8005 -)
Bosch SHU3322 UC/06
Bosch SHU3322 UC/11
Bosch SHU3322 UC/12
Bosch SHU3322 UC/12 (FD 8003-)
Bosch SHU3326 UC/06
Bosch SHU3326 UC/11
Bosch SHU3326 UC/12
Bosch SHU3326 UC/12 (FD 8003-)
Bosch SHU3336 UC/06
Bosch SHU3336 UC/11
Bosch SHU3336 UC/12
Bosch SHU3336 UC/12 (FD 8003-)
Bosch SHU33A02 UC/14 (FD 8211-)
Bosch SHU33A06 UC/14 (FD 8211-)
Bosch SHU33AC02 UC/14
Bosch SHU33AC06 UC/14
Whirlpool SHU40011 DISHWASHER
Bosch SHU4002 UC/06
Whirlpool SHU40041 DISHWASHER
Bosch SHU4006 UC/06
Bosch SHU4016 UC/06
Bosch SHU4022 UC/06
Bosch SHU4026 UC/06
Bosch SHU4036 UC/06
Bosch SHU4302 UC/06 (FD 7705-7912)
Bosch SHU4302 UC/11 (FD 8001-8003)
Bosch SHU4302 UC/12 (FD 8003-)
Bosch SHU4306 UC/06 (FD 7705-7912)
Bosch SHU4306 UC/11 (FD 8001-8003)
Bosch SHU4306 UC/12 (FD 8003-)
Bosch SHU4312 UC/06 (FD 7701-7912)
Bosch SHU4312 UC/11 (FD 8001-8003)
Bosch SHU4312 UC/12 (FD 8003-)
Bosch SHU4316 UC/06
Bosch SHU4316 UC/11
Bosch SHU4316 UC/12
Bosch SHU4322 UC/12
Bosch SHU4322 UC/12 (FD 8003-)
Bosch SHU4326 UC/12
Bosch SHU4326 UC/12 (FD 8003-)
Bosch SHU43C02 UC/14 (FD 8211-)
Bosch SHU43C05 UC/14 (FD 8211-)
Bosch SHU43C06 UC/14 (FD 8211-)
Bosch SHU43C07 UC/14 (FD 8211-)
Bosch SHU43E02 UC/14 (FD 8211-)
Bosch SHU43E05 UC/14 (FD 8211-)
Bosch SHU43E06 UC/14 (FD 8211-)
Bosch SHU43E07 UC/14 (FD 8211-)
Whirlpool SHU45010 Dishwasher
Whirlpool SHU45020 Dishwasher
Whirlpool SHU50041 Dishwasher
Whirlpool SHU50043 Dishwasher
Bosch SHU5302 UC/06 (FD 7705-7912)
Bosch SHU5302 UC/11 (FD 8001-8003)
Bosch SHU5302 UC/12 (FD 8003-)
Bosch SHU5304 UC/06 (FD 7705-7912)
Bosch SHU5304 UC/11 (FD 8001-8003)
Bosch SHU5304 UC/12 (FD 8003-)
  #2 (permalink)
Old 07-30-2013, 03:59 PM
Junior Member
jharney is on a distinguished road
Default follow-up question
Md D-
I want to try your fix, but am a little confused.
Could you please explain by what you mean by "power down" (does this reset the wash?)
Also, after resetting, do I leave door open? Or close it before I start again?
Thanks!
  #3 (permalink)
Old 08-10-2013, 11:51 AM
MrD MrD is offline
Junior Member
Default
Hi JH,
First I want to tell you that my dishwasher is still working perfectly.
If you are having the same problem as indicated in my original post ... The "dispenser reset" process worked like this:
1) Begin a new load, just as you normally would, except no dishes or soap. (BE SURE to close the soap dispenser door before starting the load).
2) After about 15 minutes (not an exact science), "CAREFULLY" open the door to interrupt the dishwashing operation.
3) Check to see if the soap dispenser is "open".
3a) If the soap dispenser door is open, there is a good chance that this fix will not work for you. If the door is open, simply close the door and let the dishwasher complete the cycle and look for a different solution).
3b) If the soap dispenser is still closed, turn "OFF" the dishwasher with the Power (On/Off) button.
4) Wait about 15 seconds after turning the unit off ... then turn the unit back on and close the door. This should start a new cycle. Run the FULL CYCLE. This may seem a waste especially if the dishwasher is empty; however, you must allow the cycle to run to completion (do not interrupt).
At the completion of the Full Cycle, if your problem was caused by the same issue I was having, your soap/rinse timing has been reset. The soap dispenser door should have opened and you are ready to begin using the dishwasher as normal.
I hope this helps.
  #4 (permalink)
Old 08-14-2013, 01:38 PM
Junior Member
Default
Thanks!!! Before you replied, my problem was fixed by switching to Finish Powerball tabs and the door has been opening as it should ever since.
I will keep your reply/solution just in case mine stops working again.
I appreciate it! JH
  #5 (permalink)
Old 08-14-2013, 06:31 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Try to avoid using pods or pouches i've seen remnants in machines that didn't completely dissolve........Also avoid using soaps like Kirkland, Arm and Hammer, Sun, Purex......Good luck
  #6 (permalink)
Old 10-11-2013, 08:28 AM
Junior Member
danstyk is on a distinguished road
Default
Thanks for this suggestion - trying it now, and hopeful since after 20 minutes when I checked, the dispenser door was still closed. Wondering if my detergent might also be an issue -- I got some from Trader Joe's recently. What kind do you recommend?
  #7 (permalink)
Old 10-11-2013, 11:47 AM
Junior Member
Default
Did not seem to do the trick yet. I interrupted it and ran a full cycle, then loaded in some dishes and soap. When I peeked at it mid-cycle the door was open but soap not fully discharged.
I could say maybe I should not have interrupted it, but the other cycles we ran ended the same way, with half the soap left.
  #8 (permalink)
Old 12-19-2014, 02:47 PM
Junior Member
okii is on a distinguished road
Default
Is it possible that the quantity of water supplied to the dishwasher is not enough to dissolve and dispense the soap? How can you check if you are getting enough water into the dishwasher?
Has there been problems with the small plastic lever that releases the soap door getting stuck?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
BOSCH Dishwasher Soap Dispenser dldowell Dishwasher Repair 0 04-08-2012 04:17 PM
Bosch Dishwasher Soap Dispenser stevefrank Dishwasher Repair 1 10-05-2010 02:39 PM
Dishwasher not dispensing soap Darrellhobbs Dishwasher Repair 0 02-25-2009 12:44 PM
Bosch Dishwasher noisy and soap not dispensing tysonjm Dishwasher Repair 0 10-10-2008 12:16 PM
Bosch dishwasher soap dispenser markac Dishwasher Repair 1 07-11-2008 07:55 PM
