Appliance Repair Forum
-   Dishwasher Repair (http://forum.appliancepartspros.com/dishwasher-repair/)
-   -   D/w stopped getting power (http://forum.appliancepartspros.com/dishwasher-repair/525150-d-w-stopped-getting-power.html)
MTech 05-01-2013 12:30 PM
I got a 4heat yr old frigidaire dish washer model #- FDB700BFC2. When i turned the start know to a wash position it had nothing. I then moved it a little bit and it came on for about 2 seconds.
I replaced the timer twice, and the panel once. And still nothing! It has power running directly to it also!
What are other options?
scott5495 05-01-2013 03:17 PM
d/w getting power
sounds like a possible door switch problem. push and hold the door tight and try starting the unit. also possible that a door switch is intermittent. separate access panel and switches will be on latch.
MTech 05-02-2013 12:22 PM
Installed a new door switch. Still not turning on! The only light that comes on is when its in the off position it says clean!
