Discuss
Fills+drains pump runs but wash arms not moving
 in
Dishwasher Repair
Hi All, Dishwasher fills can hear pump turn on after fill but wash arms are not moving. It will drain
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Fills+drains pump runs but wash arms not moving
  #1 (permalink)
Old 02-06-2008, 07:56 PM
aace73 aace73 is offline
Junior Member
aace73 is on a distinguished road
Default Fills+drains pump runs but wash arms not moving
Model Number: mdb124bhs0   Brand: White-Westinghouse   Age: 5 - 10 years
Hi All,
Dishwasher fills can hear pump turn on after fill but wash arms are not moving. It will drain itself with out problem.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-06-2008, 08:20 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Open the door after the pump engaged and check the water level and if the spray arm is spinning.
Post your findings.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 02-06-2008, 08:36 PM
Junior Member
Default
No not moving the dish's are dry and the motor is running. Hmmmm....
Thanks again
  #4 (permalink)
Old 02-07-2008, 07:15 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Most likely the problem is a bad pump which has to be replaced.
- The part number for the pump & motor assembly is AP3160640
Here are the break down diagrams for the White Westinghouse dishwasher Model MDB124BHS0
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Tappan Dishwasher fills then drains Henry R Dishwasher Repair 8 12-15-2007 07:59 PM
fills up and drains immediately dennis b Washer Repair 3 12-14-2007 12:41 PM
Fills and drains......no spin danc44 Washer Repair 5 12-01-2007 08:49 PM
Dishwasher fills then immediately drains macmantim Dishwasher Repair 0 12-01-2007 10:44 AM
Dishwasher fills and drains and runs trough cycles but doesnt wash ryan6663 Dishwasher Repair 1 10-24-2007 05:11 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
