Discuss
Got a 'screw loose'!
 in
Dishwasher Repair
A screw has come loose, that holds a roller-wheel that supports a rail, that holds the upper dish/cup
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Got a 'screw loose'!
  #1 (permalink)
Old 02-06-2008, 07:11 PM
Paul James Paul James is offline
Junior Member
Paul James is on a distinguished road
Default Got a 'screw loose'!
Brand: Kenmore   Age: 1 - 5 years
A screw has come loose, that holds a roller-wheel that supports a rail, that holds the upper dish/cup rack up. The hole in which the screw was fixed has loosened up and the screw will not hold. I have tried 'goop' and another industrial glue, as well as a plastic drywall anchor to fill the hole the screw goes into...but none have worked. Is there a glue available that will help hold this screw in place and not be compromised by the hot water temps inside the dishwasher?
Thanks in advance for your assistance.
p
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-06-2008, 08:13 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
You can try a high temperature epoxy glue which ever you will find in a hardware store.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Loose handle dougvegge Refrigerator & Freezer Repair 2 07-19-2008 11:40 AM
Loose Baffle TG2007 Dryer Repair 1 11-25-2007 07:51 AM
Loose refrigerator door handle danek Refrigerator & Freezer Repair 3 11-23-2007 08:50 AM
dishrack screw type jfazekas60 Dishwasher Repair 1 09-10-2007 07:46 PM
loose seal used upright freezer tcarlson762 Refrigerator & Freezer Repair 1 07-25-2007 12:02 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
