Discuss
Soap dispenser blocked?
 in
Dishwasher Repair
This d/w seems to be designed poorly with regard to the soap dispenser. It's situated so high on
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Soap dispenser blocked?
  #1 (permalink)
Old 02-06-2008, 06:37 PM
vw.fe2o3 vw.fe2o3 is offline
Junior Member
vw.fe2o3 is on a distinguished road
Default Soap dispenser blocked?
Model Number: GSD6200j01ww   Brand: GE   Age: 1 - 5 years
This d/w seems to be designed poorly with regard to the soap dispenser. It's situated so high on the door, it does not seem to open far enough to let all the soap out. It's blocked by the upper rack, I think. Is there a fix for this?
Is the rubber gasket on the dispenser door available separately? I can't find just that piece anywhere. I thought I might try replacing it and see if that's my problem.
Any suggestions?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-06-2008, 08:08 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Per the "Use and Care" manual (page 7) "It is normal for the cover to open partially when dispensing detergent" which means it's not broken, just design poorly.
Do not use any gel or liquid detergents - it will the problem even worse.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 02-07-2008, 07:56 AM
Junior Member
Default
I can't believe they would place the dispenser door in front of the upper rack like this. The door can just barely open, if at all. How many dishwashers have they built??? And this doesn't occur to someone?
Looks like I'm going to need to come up with a gasket replacement somehow and possibly trim a little of the upper rack away or sort of crush the first coil of it back a little bit. Just 1/2 an inch or maybe a little more should get enough clearance.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Soap lumps in dispenser henry Dishwasher Repair 1 11-27-2007 10:54 PM
Soap Dispenser Problem Gator Dishwasher Repair 1 11-05-2007 12:58 PM
Soap dispenser won't open mnbaird Dishwasher Repair 4 10-25-2007 03:11 AM
Replacing Soap Dispenser JWMc Dishwasher Repair 1 09-19-2007 06:49 PM
Soap Dispenser romeroom Dishwasher Repair 2 09-02-2007 02:18 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
