Appliance Repair Forum
-   Dishwasher Repair (http://forum.appliancepartspros.com/dishwasher-repair/)
-   -   Kenmore stuck on wash cycle (http://forum.appliancepartspros.com/dishwasher-repair/524474-kenmore-stuck-wash-cycle.html)
darren509 04-26-2013 09:31 PM
Ok so the disw washer sticks between the light wash and quick rinse cycle. So far I have replaced the timer which did not fix it. Replaced what I believe was the hi limit thermostat and did not fix it. Checked the heating element and reads 14.3 ohms. If I jumper the 2 wires that go to the new hi limit thermostat I just replaced it will work just fine ? Im confused because this is a new part, I also checked it before I installed it and it is a normally open and when heated up with a hair dryer it clicks and then shows continuity. It tests the same as the old one. What is going on with this ?
