| » Dishwasher impeller replacement |
Model Number: DU1055xtss2 Brand: Whirlpool Age: 1 - 5 years
I have a 14 month old dishwasher that has a failed bearing on the wash motor due to a leaking shaft seal. I found a replacement bearing 608-2RS and ordered it in Stainless to help stop future corrosion. After some work with my handy dremel tool I got the old bearing off and replaced both bearings on the was motor. However I also need to replace the shaft seal. I ordered a replacement impeller kit through this site (great price, fast shipping) but there is an extra washer over what was originally installed in my unit. Mine has a thick washer pressed into the impeller that the seal runs on; but the kit also came with a thin fender washer type washer that I just can't figure out where to place. Was my unit missing a washer originally or is this an extra that doesn't apply to my dishwasher? If it does need to be installed where does it belong? Thanks for any help.
Related Models |
Pump and motor parts replacement parts for WHIRLPOOL DU1055XTSS2 | AppliancePartsPros.com Was my unit missing a washer originally Cannot comment on this. is this an extra that doesn't apply to my dishwasher? Always a possibility but unlikely unfortunately I cannot find a service manual or a tech bulletin for the pump, for this unit. If it does need to be installed where does it belong? The breakdown in the Pump section does show 3 seals/washers and the order they go on. Are you sure that the metal washer is not just stuck on the back of the impeller? Sorry I could not be more helpful.
__________________
The first washer presses into a rubber cavity in the back of the impeller the second washer would be between the impeller and the seal. I feel pretty confident that this would not allow for any sealing. Thanks for your help if you figure out a definite answer please let me know; otherwise, I think I'll leave out the second washer in the picture.
James |
| Display Modes | |
| Whirlpool/Kenmore dishwasher impeller replacement | richappy | Dishwasher Repair | 10 | 07-29-2009 05:01 AM |
| how to reach circulation pump for impeller replacement | mike8520 | Dishwasher Repair | 8 | 06-14-2009 10:10 PM |
| dishwasher impeller instalation | tammydave | Dishwasher Repair | 1 | 04-11-2008 02:10 PM |
| impeller kit replacement | zeisea | Dishwasher Repair | 2 | 03-10-2008 07:40 PM |
| dishwasher impeller installation | timoteo | Dishwasher Repair | 3 | 02-22-2008 03:14 PM |
