gil.donnelly
#1 Posted : Wednesday, April 17, 2013 2:03:23 PM(UTC)
gil.donnelly
Unit will not cycle. Start button does not lite. Ran diagnostic field test indicated faulty turbidity sensor. replaced still no good. lites on control panel not functioning properly. Concidering replacing control panel next. Please advise.
Serial number 34992138JN .
Simon / APP Team
#2 Posted : Thursday, April 18, 2013 10:05:50 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The model number you provided doesn't come up.
Please check and post the correct one.
Simon.
gil.donnelly
#3 Posted : Thursday, April 18, 2013 11:41:32 AM(UTC)
gil.donnelly
Simon
The model number is recognized by Jenn Air. However the serial number 34992138JN calls for a different part for the replacement cuircuit board.Hope this helps.
Gil.
Simon / APP Team
#4 Posted : Thursday, April 18, 2013 1:25:04 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Based on the information you provided the control panel should be replaced
Part number: AP4365077
Here are the breakdown digrams and Control Panel & Door parts for Jenn-Air JDB1090AWS - AppliancePartsPros.com
Post the results.
Simon.
P.S. The first model number you posted had JBD.
gil.donnelly
#5 Posted : Friday, April 19, 2013 12:13:47 AM(UTC)
gil.donnelly
Simon:
Does the circuit board drive the control assembly or the other way around?
Is there a test to verify this is the right action? I await your advise will be gone this weekend,but will check your reply on my return.Many thanks in advance.
Gil.
Simon / APP Team
#6 Posted : Friday, April 19, 2013 1:44:02 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If there is no control panel test in the tech sheet, that mean it's not available.
If you'll get the parts from APP you may return it back thanks to our unique return policy even if you installed them.
The control panel sending commends to the control board.
Simon.
