Discuss
dishwasher won't fill with water
 in
Dishwasher Repair
When starting a normal washing cycle not enough water is going into the dishwasher. Sounds like the water is going
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » dishwasher won't fill with water
  #1 (permalink)
Old 02-06-2008, 10:48 AM
jhmorlang jhmorlang is offline
Junior Member
jhmorlang is on a distinguished road
Default dishwasher won't fill with water
Brand: Maytag   Age: 1 - 5 years
When starting a normal washing cycle not enough water is going into the dishwasher. Sounds like the water is going into the washer but not into the area where the dishes are because if you cancel the washing cycle water is draining.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-06-2008, 06:43 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
In order to provide the most accurate advise I need the complete model number of the dishwasher.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 02-08-2008, 02:03 PM
Junior Member
Default
model number MDB6601AWQ
  #4 (permalink)
Old 02-08-2008, 02:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Most likely the problem caused by the clogged water inlet valve.
In order to fix it the water inlet valve has to be replaced.
- The part number for the water inlet valve is AP3475832
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer doesn't fill with water cla Washer Repair 2 02-06-2008 04:30 PM
Dishwasher does not completely fill sammyv Dishwasher Repair 3 01-06-2008 11:01 PM
maytag washer will not fill with water wjim Washer Repair 4 12-09-2007 07:24 PM
kenmore dishwasher won't fill freundin Dishwasher Repair 0 10-26-2007 05:54 PM
GE washer will not fill with water tex Dishwasher Repair 1 08-30-2007 12:33 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
