Discuss
Kenmore Elite dishwasher won't start
 in
Dishwasher Repair
I have a Kenmore Elite dishwasher model# 665.15912001; I believe it’s really made by Whirlpool. When trying to
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Kenmore Elite dishwasher won't start
  #1 (permalink)
Old 02-06-2008, 10:44 AM
canman canman is offline
Junior Member
canman is on a distinguished road
Default Kenmore Elite dishwasher won't start
Model Number: 665.15912001   Brand: Kenmore   Age: 5 - 10 years
I have a Kenmore Elite dishwasher model# 665.15912001; I believe it’s really made by Whirlpool. When trying to start the dishwasher nothing happens, no LED’s blinking or anything else. I've verified the machine has AC power. I replaced the electronic control board (part #8194200) and the heater assembly as a pair, but it did not resolve the problem. The thermistor reads about 61K ohms at room temperature and about 12K ohms when pouring hot water into the tub. The continuity of the thermal fuse (TCO) reads 0.2 ohms. Also when checked with a DMM, the overfill and door switches operate correctly. Diagnostics will run and all LED's on the front panel will illuminate upon the start of diagnostics. The dishwasher appears to fill, cycle, wash, and pump correctly while in diagnostics. However, the dual digit LED display doesn’t show the cycle numbers (88, 10, 9, 8, 7, 6, 5…1) correctly while sequencing through the diagnostics as illustrated in the cycle time chart. When starting diagnostics the digital display shows 88 but afterwards random segments of the 7 segment LED’s illuminate during the different cycles with no resemblance of real numbers. I timed a complete diagnostic run at approximately 3:37 which matches the service technician’s documentation (3:34). On the front panel the only switches that seem to work are Hi Temp Scrub, Sani Rinse and Air Dry; at least when these switches are depressed the corresponding LED indicators illuminate. All the other switches seem inoperative. I’m thinking the front panel (part #8269611 with insert and overlay) might be defective but I have no good way to verify it and the part is pretty expensive ~$120 to replace in a 6 year old washer. Also, I didn’t think the front panel normally goes bad. Any help is appreciated.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-06-2008, 06:41 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem is a bad key panel.
I replaced a lot of them due to the same problem as yours.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 02-06-2008, 08:32 PM
Junior Member
Default
Gene,
Thanks so much for responding so quickly. By key panel I'm assuming that you're referring to part number (8269611), is that correct? If so, I'll order the part and give it a try. Thanks again.
  #4 (permalink)
Old 02-06-2008, 10:50 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Yes, this is the part you mentioned.
The OEM part# 8269611 is the Appliance Parts Pros item# AP3138235.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
noisy Kenmore elite achrispyfinn Dishwasher Repair 1 04-25-2008 07:18 PM
Kenmore dishwasher, no start bmaroney Dishwasher Repair 7 01-31-2008 09:37 AM
Kenmore Elite Dryer Karen Lomba Dryer Repair 2 12-31-2007 09:23 AM
Problems with Kenmore Elite kidao35 Dryer Repair 3 11-02-2007 04:33 AM
Kenmore Elite E1 Sensor collins66 Dryer Repair 3 10-05-2007 02:50 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
