Hello, I am in the process of replacing the bearing, hub & seal on my washer. I am stuck on the removal of the hub from the shaft. Do i need a special spanner wrench for this model or is there a standard size wrench that i can purchase? Are there other special tools I need? The AppliancePartsPros no longer carry the removal tools for this. If I cannot locate a spanner wrench, is it possible to split the hub off without damaging the machine, the hub appears to be pretty thick aluminum?
Thanks for your advice.
