Water enters tub and dribbles out arms during wash cycle. If I add several cups water to the tub the arms turn and water pressure out of arms is good. I ran through a complete wash with good results after adding water to the tub. When I run the water and system test by pressing start dry, I get no flashing error codes other than "ra" which I think refers to rinse aid low. Question is would I get a error code if the water inlet valve is defective? Is there any other reason the water level in the tub is iow?
