Discuss
Bosch Spray Arms not Spraying
 in
Dishwasher Repair
My dishwasher is not cleaning the dishes. The soap does drop from the dispenser in the door. Water is coming
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch Spray Arms not Spraying
  #1 (permalink)
Old 02-05-2008, 06:25 PM
jjfrett jjfrett is offline
Junior Member
jjfrett is on a distinguished road
Default Bosch Spray Arms not Spraying
Model Number: SHU66C05UC/14   Brand: Bosch   Age: 1 - 5 years
My dishwasher is not cleaning the dishes. The soap does drop from the dispenser in the door. Water is coming into the dishwasher and draining. However, it seems that no water is spraying from the spray arms.
What are all of the possibilities, and how and where do we check everything we need to check? We seem to be reading about foreign object(s) being lodged somewhere. Where exactly do we check for this (aside from in the filter) and are there any other possibilities whatsoever?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-06-2008, 03:29 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem caused by the circulating (wash) pump which got stuck. In most cases it could be fixed (if the motor is still good) by replacing the impeller kit.
Remove the bottom panel and listen to the main motor during the wash cycle.
If it makes a noise - most likely the motor is good.
If it's completely dead then the whole pump & motor assembly has to be replaced.
In order to repair or replace the pump - the dishwasher has to be removed from the cabinet.
- The part number for the impeller kit is AP2802376
- The part number for the pump & motor assembly is AP2826384
Here are the break down diagrams for the Bosch dishwasher Model SHU66C05 UC/14 (FD 8211-)
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 02-07-2008, 06:14 AM
Junior Member
Default
Thanks! With the sides off the dishwasher, we started a cycle. My husband said there was no movement from the motor. He has decided that it's the motor. I hope that will fix it.
  #4 (permalink)
Old 02-07-2008, 08:50 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Before replacing the motor check if 120V is coming. If not it could be the control module.
__________________
  #5 (permalink)
Old 02-07-2008, 11:20 AM
Junior Member
Default
He said he did check that and the motor was seeing 120V on one of the terminals.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher not cleaning,water not hot, spray arms not working postofficepatty Dishwasher Repair 0 01-29-2008 06:22 PM
spray arms not turning jon6180 Dishwasher Repair 1 01-17-2008 04:50 PM
dishwasher wont spin the spray arms 99 dieselford Dishwasher Repair 1 12-09-2007 05:27 AM
dishwasher not spraying dishes SPUD Dishwasher Repair 1 10-23-2007 03:48 AM
DW arms won't spray the water rflores Dishwasher Repair 1 08-07-2007 10:24 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
