Register | FAQ's | New Posts | Today's Posts | Extras |
» Dish washer won't dispense water. |
![]() Model Number: Newton Iowa 50208 Brand: Amana Age: 5 - 10 years
![]() Everything seems to be functioning out side of the fact that it won't dispense any water. I have checked all the water lines and connections with no results. Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() A model number may help others help you
Find your model number - AppliancePartsPros.com Check that the float switch (overfill) is being activated (closed) Sometimes the float can get stuck in the up position. If it is then usually cleaning it will fix the problem. If the overfill switch is being activated, check for 120 volts across the fill valve when it should be on. If there is no voltage, check across the fill valve/overfill switch combo. If there is no voltage there, then the control board is probably toast. If there is voltage, then check across the overfill switch. If there is voltage across the switch then the switch is shot. If there is 120 volts across the fill valve then either the fill valve needs replacing or it's filter needs cleaning. There is a screen filter built into the input side of the valve. Remove the valve from the unit and check/clean the screen filter. Do not permanently remove the screen filter from the valve as it is there to keep crud out of the valve which could hold it open and cause a flood.
__________________
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
washer wot dispense water | janm | Washer Repair | 1 | 04-22-2011 10:28 AM |
Dish Washer Will Not Take Water | givemeabreak | Dishwasher Repair | 3 | 01-01-2011 02:55 AM |
dish washer not draining all the way leaves just a little water | marvin midnightshadow | Dishwasher Repair | 0 | 07-18-2010 09:20 AM |
No water in the dish washer | jwdyck | Dishwasher Repair | 0 | 10-11-2009 08:33 AM |
Dish washer will not fill with water | sarah tredrea | Dishwasher Repair | 1 | 02-25-2009 05:47 PM |
