Appliance Repair Forum
-   Dishwasher Repair (http://forum.appliancepartspros.com/dishwasher-repair/)
-   -   Dishwasher (http://forum.appliancepartspros.com/dishwasher-repair/521533-dishwasher.html)
Hugey 04-01-2013 03:36 PM
Dishwasher
Dishwasher was dead.Diagnosed a bad timer. Replaced it, and it worked a few minutes, and shut down again!
Simon / APP Team 04-02-2013 12:24 PM
Hi.
Please provide more info. What was the original problem? What makes you think it's the timer? What do you mean "shot down"?
Simon.
Hugey 04-02-2013 12:49 PM
Simon,
Thanks for responding Original problem was that it completely died. Circuit tester showed no reading going out of the timer, so I replaced it!
And it worked for 10 minutes, and then shut down completely again, meaning it stopped working all together, and the electrical outlet is still live. So I am thinking the motor is old and it seized up! Maybe it took out the new timer too? what are your thoughts?
Rob
Simon / APP Team 04-02-2013 03:34 PM
Hi.
Check the latch mechanism, the latch switch.Make sure you are getting the 120VAC through the switch to the timer. A lot of times there could be a bad connection in the junction box behind the toe panel(on the right).Do not use circuit tester, use a multimeter.
Post the results.
Simon.
