Discuss
GE Profile dishwasher not cleaning well
 in
Dishwasher Repair
My GE profile dishwasher is not getting the dishes clean, primarily in the upper rack. Looks like the upper spray
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » GE Profile dishwasher not cleaning well
  #1 (permalink)
Old 03-30-2013, 05:25 AM
Junior Member
edjr is on a distinguished road
Default GE Profile dishwasher not cleaning well
Brand: GE   Age: 5 - 10 years
My GE profile dishwasher is not getting the dishes clean, primarily in the upper rack. Looks like the upper spray arm is not rotating and is clogged with food particles. Any suggestions on how to fix?
  #2 (permalink)
Old 03-31-2013, 06:30 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
A model number may help others help you.
Find your model number - AppliancePartsPros.com
__________________
  #3 (permalink)
Old 03-31-2013, 09:09 AM
Junior Member
Default
The model # is PDW 7800J10BB
Edjr
  #4 (permalink)
Old 04-01-2013, 04:14 AM
Senior Expert
APP Volunteer
Default
Parts for GE PDW7800J10BB Dishwasher - AppliancePartsPros.com
You said that the upper spray arm holes are plugged so I would clean out the holes.
The easiest is to do this when they are wet, Then try to pull the chunks out using tweezers.
Then let it run for a minute or so and do it again till all the holes are clean.
For tubborn chunkc try pushing them back into the arm and they may then flsu themselves out.
You could also remove the upper spray arm and try flushing it out.
I personally have not had much success doing this.
Seems I can never get all the chunks out so end up having to use the tweezers.
__________________
  #5 (permalink)
Old 04-01-2013, 07:55 AM
Junior Member
Default
I have tried that multiple time and put the o-ring in the back where the water feeds thru. I have just ordered a new spray arm and hope that that works.
  #6 (permalink)
Old 04-02-2013, 01:29 AM
Senior Expert
APP Volunteer
Default
Since spray arm holes are clogging up I would also check/clean the filter basket (item 508 in the Body parts section) in the sump.
I thought you were referring to the top spray arm not the center spray arm.
Check if the top spray arm is also not rotating.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Profile Self Cleaning Issue rrrichards Oven Repair (including Ranges and Cooktops) 0 01-31-2012 08:00 AM
ge profile gas range not working after self cleaning nzirons Oven Repair (including Ranges and Cooktops) 0 04-24-2011 11:37 AM
dishwasher cleaning cgarr Dishwasher Repair 3 04-20-2011 02:07 PM
GE Profile wont work after self cleaning Innneedofhelp Oven Repair (including Ranges and Cooktops) 7 12-14-2009 08:17 PM
Dishwasher not cleaning wendyjones Dishwasher Repair 2 11-25-2007 09:11 AM
