Discuss
dishwasher leaves about an inch of water in bottom
 in
Dishwasher Repair
Hello. I have a GE mdl GSD4060n10ss dishwasher that does not drain all the way out. I have replaced the
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » dishwasher leaves about an inch of water in bottom
  #1 (permalink)
Old 03-28-2013, 11:42 AM
Junior Member
Awerfam5 is on a distinguished road
Default dishwasher leaves about an inch of water in bottom
Brand: GE   Age: 1 - 5 years
Hello. I have a GE mdl GSD4060n10ss dishwasher that does not drain all the way out. I have replaced the solenoid and armature pin to no avail. Also I dont believe its clogged because I removed the drain hose and the basin will drain from gravity. Motor spins during all cycles and drain solenoid functions as it should? Please Help.
  #2 (permalink)
Old 03-28-2013, 01:16 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Check the air-gap for blockage, then the collection chamber (#510) and most important - the ball inside the tube in the sump (#454 on the diagram).
If the ball is jammed in down position it won't drain.
Here are the breakdown diagrams and http://cdn.appliancepartspros.com/im...29406215_2.gif
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Dishwasher - Standing water (abt an inch or more) left after draining. hughesdc Dishwasher Repair 3 01-18-2012 10:11 AM
dishwasher leaves abount an inch of water in the bottom robbob41 Dishwasher Repair 1 12-11-2011 07:56 AM
Dishwasher won't drain fully, leaves dirty water dcatotti Dishwasher Repair 0 06-14-2011 02:44 AM
Dishwasher doesnt drain all the way..leaves nasty cloudy waters at bottom Lisamariesmith Dishwasher Repair 0 02-24-2011 07:25 AM
washer leaves inch of water when done mowsise Washer Repair 1 07-30-2009 04:18 PM
