AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
GE Triton XL Normal Wash Rinse won't drain now won't start
We started having problems with the Normal Wash not completely washing, started using Pots & Pans setting, which worked great, but sometimes had to re-rinse-a lot of 'foam' seemed to be left in the bottom and coating the dishes. Went back to Normal wash, but, now the Normal Wash won't drain. Rinse won't drain. Took apart the valve and made sure there was nothing clogging in the drain basin and valve. Now, Rinse and Normal Wash cycle, when you push the button, just clicks, hums, and shuts off-won't start. But, Pots and Pans Cycle works fine.
Dishwasher Repair
