| » Dishwasher Leaking From Under Door |
Model Number: DWU5902AAB Brand: Maytag Age: More than 10 years
My Maytag Dishwasher (DWU5902AAB) is leaking from the front door. This isn't a new problem. It has leaked every so often from the time I moved into the home four years ago until now. I started to pay greater attention though after having some work done in my kitchen.
Here is what I have tried to do so far:
So, while I realize this is an older unit and there is some significant rust damage from years of water leaking over this edge, I really do not want to replace it at the moment. Mechanically and electrically, it works great. It washes dishes very well, and has no other problems. Also, my wife and I just had to replace our refrigerator, so we're hoping to avoid buying another appliance at the moment. I'm looking for guidance on what to do next. Most repair places I have talked to are at a loss after I tell them what I have already done. I can conclusively say that the water is not coming from the dispenser latch. It definitely appears to be coming from splashes that come up over the lip of the drain pan where there is no gasket or seal. I checked my washer for levelness and it's pretty much dead from side to side and front to back. The water level during a cycle just touches the bottom of the metal heating ring inside of the machine. I cannot seem to find a single thing. I'm desperately hoping that someone here has something else for me to try. At this point, I'm reluctant to run the machine unless I am present because I fear that one of these times, it's going to leak significantly and create some damage. I refuse to give up on the machine at this point until someone can convince me that it's going to cost more to fix than it would be to replace. I sincerely thank you for any assistance. Ads By Google Related Models |
I just resolved a similar problem I was having with my 16-month-old dishwasher. I tried most of the things you mentioned here. Last night I figured out my problem. The vent in the door was completely clogged. When water would turn on, the pressure was being released between the door and the tub. When I cleaned the vent, the problem went away.
One more thing to try at least. Good luck! Vito |
I had read that before too. I tried looking at the vent assembly for my model and there didn't seem to be much to it.
Parts for Maytag DWU5902AAB Dishwasher - AppliancePartsPros.com Also, it didn't appear like there was any water leaking in between the door panels anymore. It appears like it's splashing over the bottom and out from the underside of the door. I really don't understand why there isn't a seal there. It seems like an odd design. Since I have ran the unit without the door panel on, I don't see any water leaking from the top part of the door and running down. Unless I am missing something, it only seems like it could be coming from bottom and splashing over the lip in the drain pain. |
| Display Modes | |
| Dishwasher Leaking from Door | CMZ001 | Dishwasher Repair | 1 | 04-30-2012 07:46 AM |
| dishwasher door leaking | mimi | Dishwasher Repair | 7 | 11-22-2011 06:11 PM |
| Dishwasher leaking around the door | mommakimmie | Dishwasher Repair | 1 | 10-15-2010 08:32 AM |
| Dishwasher Door Leaking | LVHomeHandyMan | Dishwasher Repair | 0 | 04-17-2010 10:24 AM |
| Leaking dishwasher door | flowboard | Dishwasher Repair | 1 | 10-03-2007 08:52 PM |
