| » Massive Door leaks |
Model Number: KUDS01FL221 Brand: Kitchen Aid Age: 5 - 10 years
My Kitchenaid dishwasher is experiencing pretty major leaks from what seems like the front left corner of the door. The water is at the correct level, unit is level and the leaks do not start until the wash cycle vs the initial rinse cycle. There does seem to be good washing action inside the unit and I can hear a good amount of water hitting the inside of the front door. I checked to see if a pot or pan was causing misdirection of the spray but even when empty, it leaks. I should probably replace the outer door gasket seal anyway but the leak (flood) just started out of the blue vs getting worse over time. It would leak badly once, then not leak for a few days and then leak badly again.
I think the upper washarm is functioning properly but it is hard to tell. I would appreciate any advice |
The first thing I would check at time of the water leak is how much suds are inside the dishwasher.
Regular automated dishwasher soap does not create any suds which could cause water leak through the door. Excessive amount of suds (and water leak as a result) could be created by a spilled or leaked out rinse aid or a wrong soap came into the dishwasher from the prerinsed dishes (if used). The second thing I would check is the proper connection of the manifold tube (#6 on the upper wash parts) into the upper feed tube (#1 on the upper wash parts) and the hanger (#7 on the upper wash parts) being in place. Here are the break down diagrams for the Kitchen Aid dishwasher Model KUDS01FLSS1 Gene.
__________________
Professional appliance repair in Los Angeles, California. |
| Display Modes | |
| Whirlpool Dishwasher Door Leaks | snakeman56 | Dishwasher Repair | 5 | 03-21-2008 07:18 PM |
| door leaks when washing | explorerdude | Dishwasher Repair | 0 | 02-02-2008 10:01 PM |
| Dishwasher door leaks only in rinse cycle | sltweeton | Dishwasher Repair | 0 | 01-26-2008 02:18 PM |
| water leaks front door needs gasket? | chiko | Dishwasher Repair | 0 | 01-25-2008 12:56 PM |
| Dryer suddenly using massive amt of electricity | rgreeeno | Dryer Repair | 1 | 11-06-2007 11:31 AM |
