dw was leaving food on dishes/glasses. checked the inlet water temp (immediately after filling DW and after it was running a while) and the water was the same temp as from the faucet.
this unit has the water heater built into the pump and I am looking for chart to help identify what the ohm meter readings should be to help isolate whether it's the circuit board, heater or wires.
thanks
