| » Leaking under door & not draining fully |
Model Number: MDBTT59AWW Brand: Maytag Age: 1 - 5 years
My Maytag MDBTTF9AWW is leaving water at the very front of the tub after draining and is leaking underneath the door. Could the problem be the bottom door seal or is it because there is some water still left after the draining?
Quote:
There may be a minor amount of water around the pump seal in the center, and in the center of the pump the water may be as high as the top of the dome mounting screws, but there should be no more than that after a cycle, unless you have an issue with the previously mentioned checks or a restricted drain line or drain pump.
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Also make sure there are no bubbles in the water during wash and/or rinse cycles.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
I have now removed bottom kick plate. Motor is not touching floor. Bottom wash bar is not cracked, nor do I see any debris. No bubbles were seen. I am not familiar with what to do regarding drain line, etc. Water is dripping from middle of door onto floor. Will purchase a level tomorrow and see if that is the problem. Thanks for the 2 response I have gotten so far. |
Quote:
Automatic dishwasher detergent and rinse agent, should not "suds" or "foam" if used properly. If suds or foam develops inside the dishwasher, this affects the operation of the pump(s) and the washability of the dishwasher.
__________________
Quote:
I have done all the things you mentioned above and everything checks out. I did find some gunk near the bottom of the door ( I suppose maybe detergent accumulation). I though it might be keeping the bottom door latch from closing tightly by forming a gap so I removed it with a damp rag. Now my problem is worse. I now have 2 steady drips instead of 1 slow drip. I see nothing around the door gaskets leaking & this model does not have a bottom door gasket. Any ideas? |
Quote:
As for checking the drain line, disconnect the end of the drain hose from the disposal or plumbing, start the dishwasher and let it run a couple of minutes, Cancel the cycle and allow the dishwasher to drain into a large bucket. You may want to do this a couple or three times. If all checks OK, you'll need to remove the pump cover and check the drain baffle Part number: AP4566191 in the tub, make sure the flappers(4) are not distorted or rolled up. Though this is not a "common" issue, you may have to check the inner door liner Part number: AP4009552 To see if it is warped, and not sealing against the bottom flange of the tub.
__________________
I checked the drain line by letting it run into a bucket 3 times but found no debris. I am now trying to get to the drain baffle that you mentioned. I removed the upper wash arm & now can't figure how to get those screws out of the filter pit to proceed. I don't have a screw driver to fit, when I am looking at the enlarged part screen it looks like their are just round holes in the screws, no slats. I hope this will fix the problem when I figure it out. I still don't understand why the drip got worse after I removed the beaching. If you can answer my questions about the screws, I will continue trying. Thanks
Quote:
Quote:
__________________
Thanks for the help. The last part I have removed now is the rotor. The next step are the motor seal parts. It looks like a yellow screw, not sure whaind of screw that is, I tried the torx. I am about half way to the drain baffle. Maybe if I get help with this screw, I will be much closer to the baffle. I hope im not being laughed at too much, but sometimes a girl has to ask questions, right? Thanks for any help.
| Display Modes | |
| Dishwasher not fully draining | gciccol | Dishwasher Repair | 5 | 07-04-2012 10:00 AM |
| Caloric Dishwasher Door Leak & not Fully Draining | DjC4 | Dishwasher Repair | 0 | 12-30-2010 07:21 PM |
| Dishwasher not fully draining | JandLKay | Dishwasher Repair | 1 | 08-10-2010 05:51 AM |
| wash maching not fully draining | SueMooney | Washer Repair | 1 | 11-20-2008 05:07 PM |
| Brand New KitchenAid Dishwasher Not Fully Draining | lmkelly1 | Dishwasher Repair | 3 | 10-21-2008 06:35 PM |
