Discuss
Leaking under door & not draining fully
 in
Dishwasher Repair
Originally Posted by lr9147 Thanks for the help. The last part I have removed now is the rotor. The next
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Leaking under door & not draining fully
  #11 (permalink)
Old 03-14-2013, 02:27 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Originally Posted by lr9147 View Post
Thanks for the help. The last part I have removed now is the rotor. The next step are the motor seal parts. It looks like a yellow screw, not sure whaind of screw that is, I tried the torx. I am about half way to the drain baffle. Maybe if I get help with this screw, I will be much closer to the baffle. I hope im not being laughed at too much, but sometimes a girl has to ask questions, right? Thanks for any help.
Lr, You're doing fine. We're trying to avoid removing the pump assembly from the tub, but we may have to. Once you get that #15 torx screw backed out of the impeller, and slip the impeller off the shaft you're done, so you're actually more like 3/4 of the way. Try this, Insert to torx tip into the screw, tap the top of the handle with a small hammer or wrench, hold the impeller with one hand and turn the screw with the other, Sometimes the "tap" breaks the screw loose from the threads and you can remove it.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #12 (permalink)
Old 03-14-2013, 03:55 PM
Junior Member
lr9147 is on a distinguished road
Unhappy
I can't get the screw to budge even after tapping. I'll keep at it for awhile longer. Then get back at it tomorrow
Quote:
  #13 (permalink)
Old 03-14-2013, 04:24 PM
Junior Member
Default
I hope I am not too confusing. You do know that the screw I am talking about has a plastic or rubber top? The torx doesn't feel like it is getting hold of anything when I try to turn the screw.
  #14 (permalink)
Old 03-15-2013, 06:40 AM
Senior Expert
Default
Lr, Stop... We're working in two different areas. Sounds like you're trying to remove the lower spray arm nut ???
Part number: AP4113393
The impeller screw
Part number: AP4113595
Has a rubber seal under it and it can make things difficult, but nothing like you're describing.
Tell you what, repost with an e mail address, and we can send you more information that will make things easier.
Thanks,
__________________
Joe M. APP TEAM
  #15 (permalink)
Old 03-15-2013, 10:26 AM
Junior Member
Default
I am at the Motor Seal kit, part # AP4365097.
  #16 (permalink)
Old 03-20-2013, 10:16 AM
Junior Member
Default
Joe,
Thanks so much for all your help, patience and encouragement. I finally got everything back together. It was quite a job, but well worth it for me, not only did I save a lot of money, which is very important to me, but I also learned a lot in the process, thanks to you. After giving my dishwasher & parts a good cleaning from the hard water/detergent residue, I just got it all back together & did a test run and it's not leaking now!! I'm still not sure what caused the leak, I saw nothing obvious, but its not leaking! Hopefully it will stay this way.
You guys at Appliance Parts Pros are awesome, what a service! I have used you once before for my clothes dryer with good results also. I will & have highly recommended you.
  #17 (permalink)
Old 03-20-2013, 11:03 AM
Senior Expert
Default
Joe,
Lr,
Thanks for the update, We're glad you stuck with it .
Thanks Again
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher not fully draining gciccol Dishwasher Repair 5 07-04-2012 10:00 AM
Caloric Dishwasher Door Leak & not Fully Draining DjC4 Dishwasher Repair 0 12-30-2010 07:21 PM
Dishwasher not fully draining JandLKay Dishwasher Repair 1 08-10-2010 05:51 AM
wash maching not fully draining SueMooney Washer Repair 1 11-20-2008 05:07 PM
Brand New KitchenAid Dishwasher Not Fully Draining lmkelly1 Dishwasher Repair 3 10-21-2008 06:35 PM
